AH FabricationsVolks Autos
Results 1 to 7 of 7
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    Solid or Dual Mass flywheel?
    whats the difference between the both?
    why is the solid one cheaper and people say its better?
    any help would be awsome
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Dual mass is essentially sprung so that gear changes are smoother when you release the clutch. if you can drive properly your left foot can achieve the same thing, and lose the extra inertia generated by the dual mass.
    I believe the weight difference is 6.3kg single mass / 9.9kg dual mass.
    If you are changing it anyway, when go for single mass as its cheaper.
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    Trick's Avatar
    Sep 2008
    161
    It the dual mass fitted as standard on the S3?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    Quote Originally Posted by Trick View Post
    Yup
    You've got to have a laugh!
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    Is it a lot more noticeable having the solid one? I really dint wanna risk all the fitting charges to find it's poop !
    -AUDI A3 1.8T-
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    You get a rattling noise from the gearbox on idle IIRC
    <tuffty/>
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    Try and get a drive of a VR6 mk3 Golf, as that is the hardware you are fitting essentially.
    4cyl flywheel, VR one WILL NOT bolt to the 4cyl crank and a VR6 Clutch, which will handle some extra power.
    I had one in my A3 and it's not as bad a people make out. IMO
    Gavin
