Chris NottAH Fabrications
Results 1 to 36 of 36
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    Just got a Revo remap and...
    and something doesnt seem quite right.... how should it feel to drive after it?
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,883
    Quote Originally Posted by zeeeebo View Post
    FAST(er) than before.
    You've got to have a laugh!
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    yer but how much faster? also it seems to stick a bit like when i put my foot down its almost like the clutch is dipped a bit
    -AUDI A3 1.8T-
    Jun 2009
    1,064
    it should feel much more responsive to.
    Its gone replaced with a mk2 golf gti 16v :D
    Nov 2004
    USofA
    15
    maybe the extra power is just making your clutch slip??
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    this did cross my mind, but its for exaple half way inbetween gear changes!
    -AUDI A3 1.8T-
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    as in i change...... then before i change again it does it
    -AUDI A3 1.8T-
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    It revs a little as you change gear? That sounds like the clutch switch... is your car drive by wire?
    Bill had a 1.8t in for a Revo this weekend and the customer said it wouldn't boost above 15psi (should be 17psi at least) and took until 4k to get there... turns out his turbo is worn out (compressor wheel) and just wouldn't make the boost despite being given the ability to do so.
    How many miles has your car done?
    <tuffty/>
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    its done 140k, i have no way of working out what psi mine is doing! i guess both the clutch and turbo need doing on mine at somepoint then! how annoyin as i just dished out 350 for the map!
    -AUDI A3 1.8T-
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    If you have 140k then its totally plausible the turbo is tired... grab yourself a cheap boost gauge off ebay to get an idea
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=370250177861
    The clutch switch is a common problem, gives the impression you haven't let off the throttle soon enough as you change gear. Bit a bugger to get too I think but cheap enough to replace.
    Do a search, there should be a few threads here that will help.
    <tuffty/>
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,639
    the map will still work when and if you change them.you might have a hose collapsing....have you upgraded the DV ?
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    if i put my foot flat down in fith for example when it raches 3 ish it feels like im bliping the clutch , then i have to come off the acelerator and feed it out slowrer!
    -AUDI A3 1.8T-
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    ah, clutch sounds like its on its way out then
    <tuffty/>
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    that will be a bit of a bummer as i just dished out 350 quid and cant afford to throw another 390 ish at it!!
    if there is also rattle when changeing gears slowly does that mean i might need a new fly wheel too? and my gears arent very easy to select so is it worth gettin a whole new box and clutch?
    -AUDI A3 1.8T-
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Problematic gear changes could be a symptom of the failing clutch and flywheel. I would change both those first (yes, its sounds like the flywheel is on its way out) and change the hydraulic actuator for the clutch while you are there as these are known to fail (will require bleeding) and aren't that expensive...
    <tuffty/>
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    rough price on all that fitted?
    -AUDI A3 1.8T-
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Just give Audi a call for worst case scenario then GSF for parts so you know what you should be paying and find a decent independent garage to fit them...
    <tuffty/>
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    whats gsf?
    -AUDI A3 1.8T-
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    also the will the standard clutch be enough now its at 190 bhp
    -AUDI A3 1.8T-
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Should be ok... not sure what size they fit on the A3, I am sure an A3 owner will be able to tell you for sure though...
    <tuffty/>
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    http://www.eurocarparts.com/ecp/c/Au...4d14029f7cddb2 would that work ok? if i upgraded to a solid flywheel?
    -AUDI A3 1.8T-
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Single mass flywheels are noisier that dual mass. Prob not running enough power to warrant the change.
    Its a bit of a grey area for me tbh so over to someone else??
    You could also have a look around cupra net (google it) as the SEAT boys aren't shy when it comes to mods and they use them a lot.
    <tuffty/>
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    I had this issue when i fitted a 007 with a green spring. The boost was not holding and felt like the car was stuttering as if the clutch was being dipped. Upgraded to the yellow spring and all problems have gone hold the boost perfectly now :D
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    ah right this is interesting! i have an uprated baileys dumpvalve that is atmospheric. i will try and put the standard one / get another one see if this makes any difference!
    i will let you know as i really cant afford money for the clutch at the moment!
    -AUDI A3 1.8T-
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    For a starter complete atmospheric valves are a NO NO on VAG's. Its recomended to stick to a re-circ valve like the Forge 007p that is very popular on this forum. If you really want the dump noise then quite a few have gone for the Forge Split-R as this is part re-circ and part atmospheric and sends just enough air back to keep the ECU happy.
    Would defo try messing around with the valves 1st as they are the cheaper option.
    2001 S3 - Ming Blue, Bose + AndyMac Stealth Sub + XCarlink iPod Interface with Bluetooth, Forge 007 (Yellow Spring), Green Cotton Panel Filter, Angel Tuning Remap, Milltek Cat-Back Resonated, Parking Sensors & Full Black Leather Nappa Recaros with Piano Black Trim.
  28. #27
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    yer my car was running fine though no error codes or anything! what was your car actually doing when yours was ill?
    -AUDI A3 1.8T-
  29. #28
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Well i bought my car already remapped with the standard Bosch valve = no issues
    Swapped the Bosch to a Forge 007p with green spring = stuttering boost
    Change the spring to an uprated yellow = no issues and smooth boost that is held all through the revs
  30. #29
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    i dont think mines stuttering, read my description a few up. i think it is the clutch cause as soon as main boost kicks in at 3k it revs up with out accelerating!
    -AUDI A3 1.8T-
  31. #30
    joe_audi1.8t's Avatar
    Nov 2008
    10
    i am currently using a standard bosh recirc valve and boosting 1.1 bar it will hold it in 1st, 2nd, then end of 3rd bout 5500rpm it will pin back to 0.6 bar same in 4th and 5th do you think i need to uprate the the recirc valve to something like a 007p to maybe hold this boost ? thanks
  32. #31
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    that does sound like clutch clip fella
    worse in 4th/5th gears if you full throttle from low rpms?
    as soon as boost climbs, peak torque, and revs rapidly rise without the shove in the back which goes with it, is clutch slip.. you would expect to smell the burn clutch if doing this too often... which dont btw, as you may need a new flywheel too if it gets blued too much from slipping/heat friction etc
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  33. #32
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    annoying
    does anyone know the average price for a clutch and solid fly wheel kit that will fit my a3 1.8t sport s reg?
    -AUDI A3 1.8T-
  34. #33
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Go here... http://www.gsfcarparts.com/
    Type in your postcode for a local shop and give them a call
    <tuffty/>
  35. #34
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    yer i did they said the kit itself is 380quid and they didnt even know if it would fit my car! i dont fancy payin a garage to fit somethin then havin to pay them to fit the proper one again.
    -AUDI A3 1.8T-
  36. #35
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    380 sounds about right for a dual mass flywheel and clutch kit...
    Also try http://www.eurocarparts.com/
    ...for example...
    http://www.eurocarparts.com/ecp/c/Au...ae8efdcd1d161c
    ..and..
    http://www.eurocarparts.com/ecp/c/Au...ts/Clutch-kits
    Not sure if they are the exact right parts but they do have engine codes listed... you could always call Audi and ask... you may be surprised
    <tuffty/>
  37. #36
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    yer i saw those! :D
    hopefully will buy that solid wheel kit. so do i just ring audi and ask what clutch / flywheel would fit my car?
    -AUDI A3 1.8T-
