Lightened flywheel / Dual Mass - BAM 2002 S3?
djarchive
Preston
Being a 2002 S3 and having a dual mass type flywheel / clutch set up (as standard...) Can you lighten these or not?
I of course want to keep my current set up but when the Clutch needs changing (pritty soonish) I will look to get the Flywheel done aswell *If poss*
Can somebody with more knowledge clarify / point me in the right direction as to where to buy 1 / what im actually lightening?
P.s I've tried searching toolbar on the site, using the words dual mass / lightening but to no avail.
Thanks for your help,
Joe :hi:
Any flywheel can be lightened it a case of knowing where to do it without weakening it
If i could see the flywheel i could tell you where to machine to make it a bit lighter, if i had it in front of me i could tell you i would have more idea to remove more
Cheers for the quick responce.
I'll up a picture tonight my friend :friends:
I thought it was almost impossible to lighten the Dual Mass Flywheels due to the way they are produced?
Will be interesting to know if this is possible though...
I had the Dual Mass Flywheel from my MK4 Golf removed and replaced with a lightened/balanced (and VERY expensive) one. Regretted it as soon as i picked it up, the noise was stupid!
