AH FabricationsBadger5
Results 1 to 7 of 7
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    My subs wierd. Help!
    i like my music but i have to put the bass down to -5, the lowest it can get. if i have it any higher it just makes a farting noise (best i can explain it) ha.
    does anyone know what could be the problem, and how to fix it?
    Dansmith's Avatar
    Apr 2009
    Bournemouth, United Kingdom
    460
    Quote Originally Posted by DJ-S3 View Post
    is this with the standard head unit and subs etc?
    Jun 2003
    World of my own
    9,813
    I assuming it's the Bose system you have (2 x 4" drivers in the black fronted sub). The usual cause is a broken screw on the middle of the front baffle as below:
    The plastic where the screw goes in can break which allows air to escape and the whole thing farts at any volume. Try pushing against this part of the baffle and see if the farting ceases.
    Alex Turner
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    yeah it is the standard bose head unit and subs etc.
    yeah it does stop farting if i do that andymac, does that mean plastics broken around the screw hole?
    if so is there anyway to fix this without replacing the whole thing?
    Jun 2003
    World of my own
    9,813
    Yes there is but you really need to remove it to do it. You need to take off the front panel/baffle then use a lot of araldite to glue the broken part back in place. Leave overnight then carefully screw the baffle back on taking care not to overtighten the repaired section. Or you could buy a non Bose sub on ebay for about 25 and use it's enclosure to replace the broken one as they are identical.
    Alex Turner
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    ok, cheers. think i'll try taking it out when i get her back from my friends workshop. in for some rust getting rid off the bottom of the drivers side door, alloys sprayed and buffing+polishing up
    but if i mess that up some how, do you know i link for a none bose sub?
    Jun 2003
    World of my own
    9,813
    This is what you're looking for, but this one is well overpriced (as they all tend to be from breakers):
    http://cgi.ebay.co.uk/2002-AUDI-A3-R...d=p3286.c0.m14
    Alex Turner
