Chris NottVolks Autos
Thread: headlamp washer
    Ross_S4
    Aug 2009
    Dundee
    718
    headlamp washer
    Question about the headlamp washer pump...
    Mine is knackered, the pump is pulling about 24 amps but is fused at 20 amps.
    So befor i replace it, how does it fit into the washer fluid bottle?
    I would guess there is like a rubber grommet or something similar and the old pump will pull out and the replacement push in?
    any advice?
    Ross_S4
    Aug 2009
    Dundee
    718
    Anyone? Please?
    I just need to find out how the pump is removed from the tank and refittted?
    also vag-cat had two part numbers, 3B7955681 and 1J0973722A. What is the difference (if any) between these two?
    Cheers.
