Volks AutosMonster Motorsport
Results 1 to 8 of 8
    Aug 2009
    14
    Coolant temp reading low
    Hi folks, so I've only owned my A3 quattro for a couple of months and I love it!
    But there is now a strange problem with the coolant temp gauge..
    It used to be that the needle sat right in the middle of the gauge when warmed up, but now it barely makes it over the second notch (70degs).
    Once the car is up to temp and I leave it for a few minutes when I turn the key the temp gauge goes to the middle 90 degs.
    Then when while driving down goes the temperature gauge..
    The interweb suggests it's the sender but what do you all think?
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Sender mate, had it on mine.
    Cost is about 12 quid from GSF and will take about 10 minutes to fit...easy peasy
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Sender or thermostat
    When i did mine it was the thermostat
    Black S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    This problem is common as muck on 1.8t's, had the same on my S3. Mine was the thermostat but I replaced the sender too. Stat is more of a pain to replace but as Tom said, the sender is a piece of cake and worth changing anyway.
    <tuffty/>
    Oct 2007
    111
    sounds like thermostat to me aswell, replaced 2 of these as causing the same problem on both of my a3's i've owned. if you require a temp sensor i would go genuine as i've heard that non gen ones dont last long.
    cheers mark
    Aug 2009
    14
    Sorry for dragging up an old thread but I've had a good result. Weeks ago I changed the coolant sender, but was still not right..
    Today the thermostat was done and all is well!
    Thank you all ..
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Any other symptoms of this? lumpy idle etc? thought i'd read they are connected
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Ive got a brand new temp coolant sensor if you want one?..
    A3 1.8 TURBO| RS6 18INCH ALLOYS | FORGE 007 | SMOOTHED O/E BOX WITH COLD AIR FEED | COILOVERS | MOTECH RE-MAP | FULL CREAM LEATHER | FORGE DV RELOCATION | FORGE TIP HOSE|SILICONE BOOST HOSES|REMOVED REAR WIPER|G60 FLYWHEEL & VR6 CLUCTH|MILTEK CAT BACK DISCREET SYSTEM|312MM BRAKE UPGRADE|UPRATED DOG BONE MOUNT.
