EM TuningJMB Retrofits
Results 1 to 14 of 14
    Aug 2009
    Help, a few faults :(
    Hi all,
    My name's Ian. Got a 2000 A3 Quattro Turbo. As far as I'm aware it's been remapped and has the obvious addition of an FMIC. It was flying and running great until recently.
    To quote the guy that did the vagcom for me "FMIC install looks a little slap-dash"
    Anyway, to diagnose whatever's wrong with it they'd need it in for the day and could end up costing a fortune for the diagnosis alone.
    Basically, it's running fine driving normally, but try and boost it and you'll get that initial kick then it's like it's hit a wall and won't give it anymore power.
    I'm sure I can hear the sound of air escaping which leads me to think it's a leak. Spotting where tho is a bit of a struggle. All pipes/hoses have been tightened, etc.
    The faults were as follows...
    16500 - Engine Coolant Temp Sensor
    Signal Intermittent
    16622 - Manifold Pressure / Boost Sensor
    Signal Too High
    16486 - Mass Air Flow Sensor
    Signal Too Low
    16490 - Manifold / Barometric Pressure
    Implausible Signal
    17743 - Engine Torque Monitor 2
    Maximum Limit Exceeded
    17521 - Oxygen Sensor B1 S1
    Internal Pressure Too High
    I already knew about the coolant temp sensor problem and this was about before this recent problem started.
    Am I right in thinking that an air leak could trigger all of the above?
    If anyone could suggest anything then I'd be very very greatful
    Aug 2009
    Oh, and I've been reading a lot on here and I know the usual answers are N75, 710N, MAF, MAP, Actuator arm, etc.
    I tried unplugging the MAF as recommended and it made no difference. So is it ok to rule that out?
    Is there a way I can test the Recirc, N75, MAP, etc. without buying the new parts?
    Also, coming from the N75, there's a vacuum pipe that just leads to no where and appears to have no where to plug into either
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    Hi mate, welcome to the forum!
    Firstly where are you based? We are a friendly bunch on here and serveral members will pay you a visit for the price of a beer to vagcom for you. You should really clear all faults and go for a drive to see what faults are re-occuring.
    The coolant temp sensor is vital to the engine running correctly, its a cheap part and should be replaced first.
    As for the map sensor signal too high, as a guess this will be related to the spare vac hose off your n75. It has three conection, 1 into the intake pipe, 2 a boost feed of the top charge pipe, 3 exit down to the wastegate. if this is unolugged basically your waste gate isnt opening, giving you insane boost and the relating fault!
    Let us know where you are based and then ask nicely for help.
    A1 Competition line 1.6 tdi
    Aug 2009
    Hi Ash,
    Thanks for the reply
    TBH at this moment in time I'd offer more than a beer to sort it. I don't mind paying my way, it's just the garage was far too vague to keep me feeling comfortable.
    When it is boosting on occassion it is pretty insane Not sure what pressure it's at when it is tho.
    I think it's the boost feed from the top of the charge pipe that currently has no where to go. Does this feed what the pressure is to the N75 then? I hope this is the answer to my problems, I really do lol Struggling to think how I'd connect it up tho? Is there another line I could tap into easily or anything like that?
    Really really appreciate the help.
    Oh, almost forgot, I'm based in Manchester, Ashton-U-Lyne way. I wouldn't give it a second thought travelling for the help tho.
    Oh, another edit, I'll be sorting the coolant sensor tomorrow afternoon as I have an early finish. I pass an Audi dealer on the way home too
    Thanks again
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    That would mean your boost is escaping through that pipe then. It does in a way feed the n75 pressure, have a look at this for more info on n75 operation
    http://s2central.net/images/boost_control.jpg
    There should be a connection on the metal charge pipe at the back of the engine that comes off the turbo and heads towards the i/c. There are two side by side one for the recirc valve about 20mm diameter and the other for the n75 bout 8-9 mm diam'.
    see here http://i29.photobucket.com/albums/c2...9/CIMG2613.jpg
    edit ignore the red circled bit on the photo, its not mine(google images)
    Aug 2009
    Would it mean it was escaping tho? As the hose is literally coming from the N75 and leading to no where, not the other way round. It should fit fit onto the dark blue pipe in the first diagram, which is the pipe shown in the second picture if I'm right?
    The thing is, that pipe in the second picture has been totally replaced with another one. From that pipe there is only one connection on the top and that's the one to the recirc valve, hence why this other hose leads from the N75 to no where.
    Oct 2007
    111
    sounds like the intercooler fitted by the previous owner doesn't have a n75 feed on the charge pipe persuming the charge pipe is new i.e fitted with the fmic kit. You may have to use a quick tap or drill a hole with an adapter and seal appropiately then put the n75 boost hose on that.
    i'm looking at getting an intercooler my self and this is what i will need to do as the pipe doesn't come with it.
    Aug 2009
    So you guys reckon this would be the answer to all my problems?
    In theory, I could tap into the line that goes to the DV right as it's coming from exactly the same place? Think it'd be easier doing it that way than drilling into the pipe and trying to seal it. Not that it's ideal, but it'd be easier for me to fabricate a t-piece with 2 x 20mm ends and 1 x 8mm end coming off it using plumbing gear.
    Cheers fellas.
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    well lets not jump to far in front but i would say that it should cure alot of your problems. with out an n75 feed the ecu has no idea of what boost is being created and so thats why your getting alot of boost and then nothing. what you said about tapping into the dv pipe will work fine as long as its sealed 100%.
    Get that done and the coolant sensor and you should be fixed (hopefully)
    Aug 2009
    Fingers crossed
    Will sort those out this weekend and report back. You've been a big help, Ash, cheers
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    Quote Originally Posted by Ian123 View Post
    Fingers crossed
    no worries mate, hope you get sorted!
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    How did you get on bud?
    Aug 2009
    Hey Ash,
    Sorry for late response, had a rough week last week.
    Followed through the idea and fabricated my own t-piece with 2x22mm ends and 1x8mm end with plumbing gear and EVERYTHING is sorted! Replaced the coolant sensor too (only 20) and the car is absolutely spot on now Not one single fault, as it should be.
    Thanks again
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    Glad your sorted mate!
