Sky InsuranceChris Nott
Results 1 to 21 of 21
Thread: Help On My S3
    TanyaS3's Avatar
    May 2003
    UK
    205
    Help On My S3
    Hey all
    For a few months now my S3 has had this problem.
    It does it badly when its cold. But when im driving away and put it into 3rd gear it very badly like pulls and holds back, it just doesnt want to go, it does after ive held my foot down on the gas for a few seconds but im not sure what this is and it is slightly worrying me.
    Anyone have any ideas?
    thanks
    Tanya
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,421
    Re: Help On My S3
    Sounds like the car can not get onto boost.............have you tried changing the OE Bosch DV for a new one or upgraded one?
    imported_rabs
    Re: Help On My S3
    [ QUOTE ]
    tanya said:
    Hey all
    thanks
    Tanya
    [/ QUOTE ]
    Maybe worth finding someone with a laptop and vag com to see if you have any fault codes in your ECU. That would be my first step.
    Does it make any gushing noises as you excelerate ?
    TanyaS3's Avatar
    May 2003
    UK
    205
    Re: Help On My S3
    The only thing i have done to the car is change the recirc valve.
    Nope no wooshing noises just judders bad and wont accelerate [img]/ubbthreads/images/graemlins/frown.gif[/img]
    I know no one who could plug it in and if i go Audis in b enough money
    oh dear a sick S3
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: Help On My S3
    do you know anyone with VAG.COM close by?
    imported_rabs
    Re: Help On My S3
    What area do you live ?
    I am in SouthWest
    Sep 2003
    Manchester
    340
    Re: Help On My S3
    tanya, take the DV off, push up the spring in the middle and cover all the wholes, see if it holds the pressure (if that makes sense) to see if the DV is faulty.
    TanyaS3's Avatar
    May 2003
    UK
    205
    Re: Help On My S3
    thanks for all advice
    my service light came on last night so do u think i should get audis 2 check it out when it goes it?
    im in south east. surrey
    Jun 2004
    South Wales
    47
    Re: Help On My S3
    What about giving AMD a ring? Perhaps they can give you some free advice? They also do servicing I belive.
    Or hang on til Dicky S3 rolling road day in Oct
    Chris
    imported_s3pjm
    Re: Help On My S3
    Does it misfire or judder on the motorway if you attempt to accelerate?
    Could be the bane of all a3/s3`s ,the maff meter.
    Nice skirt
    Paul
    Aug 2003
    Kent
    123
    Re: Help On My S3
    Mine has a sort of flutter when accelerating & this was looked at by Plymouth Audi when they did my service.
    Diagonsed a new MAF is required, which I am trying to get booked into Maidstone Audi to fit! This could be an early sign of the same problem!??
    I will let you know what happens when they replace it under warranty!
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,421
    Re: Help On My S3
    .........the flutter noise is normally a failed or failing Bosch DV
    Aug 2003
    Kent
    123
    Re: Help On My S3
    not a noise... a feel! hesitation type of thing!!
    TanyaS3's Avatar
    May 2003
    UK
    205
    Re: Help On My S3
    [ QUOTE ]
    [/ QUOTE ]
    yep major hesitation init
    1,361
    Re: Help On My S3
    Tanya I would suggest the first course of action is to disconnect the MAF and then take the car for a drive. You'll notice a massive loss in performance but if the car appears to run smoothly then you may have found the fault, but that's not a certainty.
    It could be the N75 or wastgate that could be causing the problem as well, but these are hard to diagnose.
    Aug 2003
    Surrey
    469
    Re: Help On My S3
    Tanya, if you're in Surrey and nearby, try calling A H Automobiles in Guildford - it's a small VW/Audi specialist and he might have some ideas. He's likely to say "bring it in and we'll have a look" but they're good guys and will tell you straight if they have any ideas.
    A.H. Autos, Unit 11, Foundation Units, Westfield Road, Slyfield Green, Guildford, tel: 01483 303942. (VW/Audi specialists.)
    http://www.honestjohn.co.uk/director...dGarages02.htm
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Re: Help On My S3
    Sounds like a coil pack fault to me...
    May 2004
    Surrey
    310
    Re: Help On My S3
    hello bk1, im in surrey!
    just thought id say hi to the local lads
    hfu
    Oct 2003
    Wimbledon, London UK
    37
    Re: Help On My S3
    i had something similiar - i took into audi wimbledon, and they replace the infamous MAF air flow thingy, and all is now well.
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    Re: Help On My S3
    you said you changed the recirc valve, did you do straight swop for another recirc valve or did you fit a dump valve in its place, Sounds like your AIR MASS METER IS FAULTY
    Up North
    36
    Re: Help On My S3
    I'd agree faulty MAF sensor from what you describe.
