It does have a built in amp, but the wiring is completely different. More importantly the rears run off the same amp in the non Bose, whereas the Bose sub amp just powers the sub, so you will lose the rear speakers as well unless you can splice in the existing amp from the setup you have, as long as it is still functioning on the rears.
Are you running the stock HU?
