Volks AutosEM Tuning
Results 1 to 14 of 14
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Wheel Alignment Issue
    Guys,
    Had two new tyres fitted to the font of my S3 yesterday as the passanger side was wearing fairly bad on the inside yet the drivers side was fine.
    I then asked then to re-align the wheels and once they got the lasers on and read what it should be set to (parrallel) off the chart, they said that it we align this according to the chart my tyres will not last!!
    Does anyone advise anything as i dont want to screw another drivers side wheel and i also dont want to rip my new tyres apart by having it set up according to the chart??!
    Cheers,
    Chris
    Aug 2004
    526
    What was the camber setting on the passenger side when measured - is it running excessive -ve camber?
    Parallel toe won't cause excessive wear like this. What were the readings they took?
    And where was this - do they know what their doing?
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Mine does the exact same thing. They put it on a 4 wheel laser alignment. they said i must have a bent shocker. as my car was on its original suspension i thought screw it, but a complete lowering kit and guess what.....its still the same. grrrrrrrr . Ive just learned to live with it.
    Audi A3 1.8 Turbo, Wietec Ultra GT 40mm kit, 3" Full Custom Stainless Steel Exhaust, Custom Code stage 1 remap, 17" RS4 Alloys, Whiteline ARB
    s3ollie's Avatar
    Jan 2007
    751
    ive been to a few places with lasers and they dont even know that anything (other than front toe) is adjustable as they normally only do toe on cars etc... i thinks its a bit of a joke when the customer need to advise the 'gargae' how to do it. Now i have found a decent garage with proper wireless digital kit and they set it how i want. Id make sure that the garage know that there is adjustments there if they dont know.
    8P S3
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,575
    You have to becareful to see if the garage can measure camber aswell and general toe, the S3 has adjusment for camber aswell as toe, to adjust them to parrallel for toe is just a safe setting.
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Do you reckon Awesome GTI in manchester will be able to sort it out?
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I recently had full four wheel alignment from Awesome GTI - I still have negative rear camber at the back, and it's still more visible on the NS. I'll dig out the report thay gave me.
    The excuse is that there is minimal adjustment available on the fixed tie bars, but i'm sure mine wasn't like that when I bought it.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Cheers Funky.
    Jun 2007
    624
    So what's the recommendation or general consensus for getting four wheel alignment done properly on the S3? Where's best to get it done?
    Someone advised me to bring it to an Audi dealer - because as mentioned here, independent places won't be aware of the various adjustments that can be made. Involves the subframe, which the majority of independent places won't go near.
    Only thing is, a mate from an Audi garage told me I'd be looking at one to two hours labour to get this done. Sound about right?
    I'm in two minds. The risk of bringing to an independent is that they f*&k it up and you end up bringing it to the Audi garage anyway. But then again, who want's to spend over 200 + VAT to simply get wheel alignment?
    Aug 2004
    526
    awesome did a good job aligning my S3 recently. Not cheap but good.
    Aug 2004
    526
    Quote Originally Posted by metricspaces View Post
    I would utterly trust my car FAR MORE with one of the reputable VAG independents for any work including alignment. Both Awesome and APS have done alignments on my S3 and i was highly satisfied with the work.
    Audi far more likely to 'f**k' it up IMHO. Alignment not as specific, but not sure why anyone would want to pay dealer prices for people who are most probably totally unfamiliar with these older cars to work on them. Bonkers conkers.
    s3ollie's Avatar
    Jan 2007
    751
    if you take it to Audi make sure you have done any mods that you intend doing first as you don't want to be doing it to soon again at that price.
    Audi use the beissbarth system and i believe it runs a set adjustment program that takes 1-2 hours to complete so i would hope the car would all be spot on and equal each side after.
    As said above there is also the sub frame that can be moved to equal camber, Castor and setback. so in the two hours Audi take maybe they are doing this as well.
    8P S3
    Aug 2004
    526
    Quote Originally Posted by s3ollie View Post
    Set adjustment programme that takes 1-2 hours??? Adjustments are done manually.
    This equipment is not only found at Audi. APS have this as do Awesome i think. 200+VAT for alignment=crazy.
    s3ollie's Avatar
    Jan 2007
    751
    i don't mean the computer does the adjusting... i know its adjusted manually.
    8P S3
