Sky InsuranceChris Nott
Results 1 to 12 of 12
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,319
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    Beeping alert on dash....
    had a rear light out, replaced the bulb, now everytime i brake i get the beep alert from the dash, any ideas
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    27,099
    Did you replace it with the correct bulb, which rear light was out & check the wattage of the old & new cause if its different it could cause bulb warnings intermittantly even if it works.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Might be the wrong bulb, also are you sure none of the others have gone since you have changed this one??
    Also check all the other lights as well, just to be sure....
    Aug 2009
    north east U.K
    1,319
    none of the others have gone, just had a brain wave, if its everytime i brake, could it be break fluid
    Aug 2004
    526
    are you talking about the DIS? if so what symbol is displayed?
    you'll only get a bulb warning when the lights are switched on (he says stating the obvious)!!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Have you checked the connection, when my bulb blow it came on the display, so changed it and was working but still showing on the display and turned out the connection was slightly lose, pushed in and secured and all was good.
    Aug 2009
    north east U.K
    1,319
    was on the display when was out, replaced the bulb and now like i say' when i brake i get the beep alert, nothing on the display
    Nilz's Avatar
    Apr 2006
    10,087
    Have yuo checked the brake fluid???
    I dont think it is to do with that, but its worth checking....
    27,099
    Uh yeah I assume you have the DIS which shows the warnings, does this not show anything when it beeps?
    Aug 2009
    north east U.K
    1,319
    Hmmm well its not fluid, this has got my head in bits,
    Purple Princess's Avatar
    Jun 2008
    Button moon with mr spoon and gang
    1,026
    Try thease..
    a- you have used a single filiment bulb and it needs to be a dule one or
    2- Its in the wrong way, Take it out and turn it 180degrees then replace it
    I had the same prob I hope it works
    Follow us on Facebook-Stacey-Byzan Photography-
    Aug 2009
    north east U.K
    1,319
    great advice, will check in the morning
