Volks AutosEM Tuning
Thread: size of tyres
    Jul 2009
    87
    size of tyres
    whats the biggest tyre you can get on an S3 without needing spacers atm i have 225 x 45 17" would 235mm or 245mm fit ok?
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Why? It's not exactly lacking in grip to start with...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    The S3 is 'over tyred' as it is. Its more a case of getting the wheel width and offset right as a rule.
    A couple of members on here have put bigger stuff on A3's IIRC, but not worth the agro/expense IMO.
    18" wheels, ET33-35 with 225/40/18's will give you the best compromise, I run 15mm rear and 10mm front spacers on 18x8 ET33 RSTT's.
    <tuffty/>
    Jul 2009
    87
    I was just looking at wheels on ebay not bothered about width just seen some with 235 tyres on them i'm just after a set of 18's to replace my 17's
    May 2009
    24
    I have just switched from 225/45/17 p6000s down to 215/40/17 eagle f1s and by god they are so much better and cheaper. they roll far less more grip everyones a winner
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Why?
    The extra grip is probably from the make of tyre. You've in fact got less rubber on the road. Less flex in side wall will give marginally better turn in etc
    But, you now have a smaller wheel circumference meaning your speedo is reading out (you'll be going faster than your speedo says)!
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
