AH FabricationsChris Nott
    viper6's Avatar
    Jun 2009
    16
    Bailey DV30 on a S3 does it require a fitting kit
    Hi all
    just bought a bailey dv30
    and read somewhere the inlet and outlet ports are larger than standard
    do you have to buy a fitting kit to fit to a audi s3 or will it fit with no probs
    also do you need to service these dV as i bought mine 2nd hand
    cheer's
    viper6
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    i just put one of these on my a3 i presume its the same, you dont really need a fitting kit only a blanking plug. if you putt out the orignal and put a blank in the hole off the air intake system. put the dumpvalve off the other pipe (off the boost pipe) and then put the small vac lead on top.
    with regards to servicing, just make sure the spring can move freely with no rubs, if it rubs put a bit of grease on it, you can do this by unscrewing all the allen keys on the top of the valve.
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Ive had one on mine for years mate, its a straight swap for the original, no fitting kit required.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    oh yer sorry just looked yours up! it is a straight swap! i thought it was the one that i have that makes the noise but its not!
    as steve said its just a unplug your old one and put in the new!
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
