EM TuningVolks Autos
Results 1 to 15 of 15
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    URGENT - HELP NEEDED CAR IN BITS
    In process of fitting new Black Diamond discs and Predator pads to front of S3. All parts removed and the old pads have a female wear indicator connector, however, the new pads have a male connector?! Visually pads look the same (shape, size, etc), is this correct?! Should I a) refit the old pads and talk to supplier on Monday or b) am I ok to cut and remove connector from old pad and fit to new pad? Urgent advice requested please guys! Thanks Marcus.
    28v6
    Re: URGENT - HELP NEEDED CAR IN BITS
    To Exchange the pads YOU CANNOT cut the connectors, to make fit, Personally I'd refit old ones until Monday and exchange the part, ***** I know but at least you'll be satisfied and have a parts warranty...
    Refit the old ones, call it a day for now and have a cool one on me!
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    cheers 28v6 ....
    but posted too late, couldnt really see why they couldnt be cut and swapped over, so I did it [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Old female connector now sits where the male one did (pad side), all soldered up and insulated off.
    All said and done panic over, disc'n'pads fitted, seem to be bedding in well!
    Will be tackling the rears next week.
    Feb 2004
    Clearfield, PA
    892
    lol fair enufff....
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    Improvisation thats the spirit they all work the same way. [img]/ubbthreads/images/graemlins/goofy.gif[/img]
    Polarity is not important either.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    make sure that you have the correct tool for winding the calliper back....pain in the arse without it and risk damaging the calliper.
    Rich
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    Yep second the right tool thing it takes no time with it and is a pain without it.
    Oct 2003
    South Wales
    2,942
    Let us know how the new pads/discs perform.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    [ QUOTE ]
    RichA3Turbo said:
    [ QUOTE ]
    [/ QUOTE ]
    Rich
    [/ QUOTE ]
    OK, so winding the rear calliper back ... i assume its notched and you push and "screw" it back in?? where do u get the tool from, expensive?? Can I manufacture a tool that will do the job..
    As for the fronts - seems to be fine, the improvisation of the connectors has worked well. Only 60 miles worth of easy bedding and they have started to bite and appear to be at least as good as standard already. Looking forward to putting them under some pressure in a few hundred miles time.
    Any advice on the rear tool (sounds a bit rude) would be appreciated.
    Cheers [img]/ubbthreads/images/graemlins/wink.gif[/img]
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    Halfords sell a suitable tool. Or if you have some square bar, threaded rod and the same size tap you could make one.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    cheers Neil
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    in what order did u bleed the brakes ?
    i think there is a certain way
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    didnt, took my time in slowly compressing the caliper with a G-clamp and removing XS fluid straight with a large syringe.
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    That's the ticket improvisation is good every time.
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    The site seems to be on a go slow and I managed to put the same post in twice.
