Volks AutosAH Fabrications
    Defratos's Avatar
    You’re Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Question VAG com ABS Brakes voltage supply problems
    I got back to the UK a few days back, and yesterday I drove my S3 (its been sitting parked up for like 4 months now). I had to jump start it, but that was it. It was driving fine until I got next to my house when the warning light and ABS light switched on so I parked the car at the house and ran a vag check. I got the below error message.
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    16-10 - Signal Outside Specifications - Intermittent
    Now I've checked my ABS brakes fuse but its working fine. Anyone know what this error code could be?
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    I'd delete the code and check it again.
    Most likely due to turning the ignition on with the battery flat.
    Gavin
