EM TuningVolks Autos
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Brake fluid level?
    I cant work out if I have overfilled my brake fluid, I cant seem to see a min-max mark on the fluid reservoir.
    How can I tell if the correct amount is in there?
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Bump, question re-worked.
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    The min max marks are on the side of the resevoir mate, unfortunately its really hard to see in the S3 because of its location, i think the max mark is level with the seam that runs around the resevoir iirc.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Quote Originally Posted by S3Steve View Post
    Thanks for the response, much appreaciated. I removed the top last night and the fluid was right at the top and as a result I think it has caused my clutch master cylinder to blow a seal because fluid is slowly driping down under the clutch pedal...
