The min max marks are on the side of the resevoir mate, unfortunately its really hard to see in the S3 because of its location, i think the max mark is level with the seam that runs around the resevoir iirc.
Thanks for the response, much appreaciated. I removed the top last night and the fluid was right at the top and as a result I think it has caused my clutch master cylinder to blow a seal because fluid is slowly driping down under the clutch pedal...
