Sky InsuranceVolks Autos
Results 1 to 12 of 12
    S3 Dave's Avatar
    Now running on Heavy Oil
    Jul 2007
    Middle England
    432
    The Iridium BKR6EIX's
    Has anyone used these plugs?? They are cheaper than the Standard plug........ Any thoughts recommendations? Can't believe there is not a sticky for plugs. :-)
    "Never in the field of human conflict was so much owed by so many to so few"
    Churchill August 20th 1940
    Jul 2009
    15
    i'd be interested in seeing what the recommendations for plugs are too. Should we just stick with OEM for S3's or is there another make(s) that members would recommend?
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    I recently changed the plugs in my car, I bought a set of Bosche super 4's from halfrauds and when they were fitted my Idle was erratic, I called Halfrauds and told them the problem and they told me to bring them back and get a refund.
    So I orderd a set of iridiums and fitted them and the car then idled fine, I discussed this with my local VW specialist and they said bosche super 4's arnt good for turbo engine's (I cant understand why) and they also recomended the Iridiums...
    So I give these plugs the
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    Jul 2009
    15
    I have just gone onto the NGKFinders website and found the plug PFR6Q6458. Does anyone know if this is the same plug used at Audi main dealers as it seems to be about 15 cheaper for a set of 4 from ebay?
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    I have those NGK PFR6Q6458 in my S3 seem ok to me got mine from GSF
    red to red black to black blue to bits
    S3 Dave's Avatar
    Jul 2007
    Middle England
    432
    Funnily enough i have been running Bosch super 4's for about 3 years without a problem. Just wanted to give these others a try. Supposed to be good for 100,000 miles. Always a varied response when it comes to plugs.
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Quote Originally Posted by S3 Dave View Post
    I guess one of the plugs could have been "bad", from the factory..
    Keeno's Avatar
    Spooly Spooly Boosty Boosty!
    Apr 2009
    West Sussex
    695
    According to the Denso rep, they've never had a plug go wrong due to manufacturing error. (Apparantly all returned faulty plugd are sent back to japan for tests)
    Also, iridiums boast a power boost of 3-4 bhp in well tuned motors....
    ...good enough for me!
    Cheap and Reliable is not Fast. Cheap and Fast is not Reliable. Fast and Reliable is not Cheap!
    banoffee's Avatar
    Jul 2009
    Surrey
    128
    Quote Originally Posted by fingermouse View Post
    got them in mine too, from ebay (searched for PFR6Q)
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    I am running the BKR6EIXs and they work very well. I was running Denso Iridium IK20s before that and when the engine got hot, the spark was getting blown out under full boost. This was due to the 1.1mm gap that the IK20 use. The BKR6EIX uses a 0.8mm gap which has eliminated my problem... THey work well
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    banoffee's Avatar
    Jul 2009
    Surrey
    128
    stock plug gap is 0.8 too
    found this handy (as first time I'd changed them on this car) http://www.wak-tt.com/225sparkplugs/225sparkplugs.htm
    ...Watching you!
    Earlsfield, London
    5,087
    Yep it is but some of the iridium plugs are larger which in theory should be fine, but when you get into higher output, it makes a bigger difference. i only foudn the cause of my problem looking at supra forums. Caused high RPM high boost misfires...was a pain in the arse!
