Sky InsuranceVolks Autos
Results 1 to 11 of 11
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    Just got my new Performance Haldex ECU
    If weather is good i will fit it tomorrow and post what i think of it
    Plan to change the Haldex oil and filter at the same time
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,637
    Visit s3 Hoggy's Instagram Channel
    Sounds good mate, be interesting to hear what you think
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    Should be fun in the wet!
    You've got to have a laugh!
    Jun 2009
    Leeds
    3,353
    Just have to find time to do it all as i'm busy in the CNC machine room most days now
    Also got to fit my ebay cooler as well
    Jun 2009
    Leeds
    3,353
    Right here is my report of the Haldex Performance ECU
    Lets start with fitting
    You don't have that much room to work with as its next to the diff filter, remove the plugs from the ECU, remove the beam bolt thats near it as this will give you a bit more room to get it out, and then unbolt the ECU and with a little wiggling of the unit it should come out.
    Refitting is the same but in reverse. follow the instructions that come with the ECU as the rubber band idea for the gasket is a good one.
    I was lucky to of borrowed a poster lift to do this but if you are on one then i would recommend that you put it in 1st gear and start the engine to look out for any leaks from the gasket
    Now what it was like to drive after?
    Well at first under normal driving nothing seamed to of changed? thats until you put your foot down then the fun begins!
    To me it really does feel like you are been pushed rather than pulled along so if your running higher boost than standard you will feel this even more, its a strange feeling but its fun, cornering is best as i was looking for 90 deg 2nd gear bends that you could put your foot down to get the rear end to oversteer witch it does, entering the corner my car understeered ( crap budget performance tyres ) then the Haldex felt it was doing that then it went into oversteer.
    The only down side is the price at 660 ish depending on were you get it from?
    Off now to go for a spin to enjoy my 50/50 torque split
    Jun 2009
    Leeds
    3,353
    Jul 2009
    87
    Sounds like fun
    Jun 2009
    1,064
    was it worth the price. ?
    Its gone replaced with a mk2 golf gti 16v :D
    Jun 2009
    Leeds
    3,353
    It depends?
    If your fitting it to a standard car then i don't think you will feel the benefits of it
    If your fitting it to a modified car with 300bhp+ then i would say it is
    My car is standard ish with only a few modification but i'm planning to do lots more to it so for me i'm just prepping the car for more power
    To me i think it will be worth it in the end
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    Quote Originally Posted by Andrew@A.L.D View Post
    .....To me i think it will be worth it in the end
    To me, that's all that matters, it's your money to spend how you will
    Glad you're enjoying it, it's something I will also do eventually, as I've heard nothing but good things about them really.
    I think we all have our "build programme" in our heads and for me this is something for further down the line.
    Something you didn't mention - how long did it take you to do?
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
    Jun 2009
    Leeds
    3,353
    How long to do
    I did it on a poster lift and it took 1 hour
    But if your doing it it on axle stands maybe twice as long?
