EM TuningAH Fabrications
    Jan 2007
    198
    AJQ engine and lambda sensors.... 1 or 2?
    All
    Got a lambda sensor error code on my 180bhp AJQ engined 1.8TQS, but is there only a pre-cat sensor on this engine, or could it also have a post cat one as well.
    I think early cars only had the pre-cat. Can anyone confirm this?
    Jason.
    Don't want to buy the wrong one as I'm gettin some lean running at higher revs and burnt out a set of plugs. Ars3.
    Jan 2007
    198
    anyone??
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    On pre 2003 there are only 1 after there are 2.
    For part numbers and help I rang ...
    Contact CES
    Head Office:
    CES (UK) Ltd
    Knutsford Way
    Sealand Road Industrial Estate
    Chester
    CH1 4NS
    Tel (Exhausts Local): 01244 379279
    Tel (Exhausts National): 01244 372555
    Tel (Catalysts): 01244 379531
    Tel (Components): 01244 377118
    Fax (All Divisions): 01244 371248
    E-mail: info@cesuk.com
    My Much Missed :Imola Yellow S3 - Revo stage 2, SPS3, RS6 reps, Pirelli P Zero Rosso, Cupra R splitter, Brembo's, 323mm EBC Turbo Grooved Discs, Ferrodo DS2500 Pads, Forge DV, Forge FMIC, Fidanza Aluminium Flywheel, Sachs Clutch, Green Cotton Dynatwist induction kit, 3" Downpipe, sports cat, Milltek cat back, Bilstein B8's, KW rear adjustable tie bars Whiteline Adjustable ARB's, Eibach Springs, Powerflex Bushes, Bose Concert System
    Now : Cupra R 225
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    AJQ has two sensors.
    Pre cat, wideband for fueling and a post cat for emmisions (measures how well the cat is doing it's job).
    Jan 2007
    198
    Oh
    is this conflicting? Or are we saying that before 2003 the AJQ has 1 and post 2003 it has the 2???
    Sorry to ask the same question after you two went to the trouble of answering
    Jason
