[ QUOTE ]
Seizure said:
[ QUOTE ]
foolish3uk said:
you can only get the three flashing indicators on vehicle with can bus voltage control units, your S3 has not got the function.
[/ QUOTE ]
Bu99er. /ubbthreads/images/graemlins/mad.gif Cheers for explaining it tho, nice one.
[ QUOTE ]
foolish3uk said:What is a dial pod?
[/ QUOTE ]
The pod with ya dials in. /ubbthreads/images/graemlins/wink.gif Speedo, Rev counter, Coolant temp, Fuel guage etc.
[ QUOTE ]
peteTDI said: vagcom can turn off the light's it on here some where
[/ QUOTE ]
I did find something on here a while ago, but it refered to an A4 or an A6, I forget which. But anyway, it didn't help me. /ubbthreads/images/graemlins/frown.gif Can't even find anything on ElsaWin with relevance to the A3/S3 either. I just want normal dials that illuminate when I switch the lights on. Is that too much to ask?
[/ QUOTE ]
is this the one that do not work?
17-Instruments: K1 -- KWP-1281
VAG-COM Works fine.
Tweak:
There are four lighting modes:
Mode 0: Nothing lit until ext. light on
Mode 1: Pointers lit all the time
Mode 2: Scales lit all the time
Mode 3: Pointers and Scales lit all the time
Mode is changed in Adapation Channel 19. Standard value should be 11000 (or something close). The first (left-most) digit is the lighting mode.
Adaptation 60,61,62
