Chris NottMonster Motorsport
Page 52 of 68 FirstFirst ... 24245464748495051525354555657585962 ... LastLast
Results 2,041 to 2,080 of 2692
Like Tree629Likes
Thread: My minor modding thread
  1. #2041
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Quote Originally Posted by Andrew@A.L.D View Post
    Mines not on meth yet as i'm still trying to find a good W/M kit
    Any old pump, any old nozzle, DO check valve and a pressure switch... its the controllers that are usually crap and tbh if you do it right there is no need for progressive... progressive just reduces the pump pressure... if you use a fairly large nozzle then at lower pressure its not going to atomise properly... I plan to try small nozzles but use a twin nozzle setup running at full pressure... have seen a similar setup work well like that...
    <tuffty/>
  3. #2042
    ap
    Jul 2010
    Northamptonshire
    37
    Sorry to interrupt you build thread with a question, how or what is the technique of getting the plastic scuttle panel to clip back into the windscreen lower channel? I replaced mine with nice new one a week or so ago and could only get the ends to lock in place.
    Andy
  4. #2043
    nanananananananan BATMAN
    May 2012
    JHB, South Africa
    1,079
    Add MIGGZ on Facebook
    Quote Originally Posted by ap View Post
    Andy
    place it on the groove and light tap it into place, but be very careful that you dont crack the windscreen, if you can use your thumbs
    My rides thread : http://www.audi-sport.net/vb/a3-s3-f...t-journey.html
    Quote Originally Posted by Paradox1 View Post
    Healthy??? no,no,noooo
    Mine is healthy
    yours is on steriods!!!
  5. #2044
    May 2012
    JHB, South Africa
    1,079
    top work as always dude. but that tank is small hey, dont know how much driving you do with the car
    Mine is healthy
  6. #2045
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    <tuffty/>
    LOVE YOUR WORK DUDE - you make things look so easy.
    Are these the only things you need to run a "DIY" WMI setup ?
    Plus the tank/fluid lines/fittings/wiring - obviously
    So my understanding is,
    Once the boost reaches the preset on the pressure switch, the pump kicks in at full operating pressure, suppling the WMI to the small nozzle(s)
  7. #2046
    May 2012
    JHB, South Africa
    1,079
    Quote Originally Posted by Scullies View Post
    elcorecto boss!
    reading gets taken off map sensor or maf
    Mine is healthy
  8. #2047
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Andy
    The channel that is 'glued' under the windscreen that the cover clips into had come unstuck... so as you push to clip it in the channel just sank down so there was no way you could clip it in... I carefully removed this and cleaned it up... using silicon sealant to 'stick' it back to the bottom of the windscreen then I used some hotglue to support the channel as there was a massive gap which I guess if it was stuck on using the proper stuff would not be an issue but I didn't have any to hand...
    This supported the channel well enough to enable me to push the cover back into the groove...
    Quote Originally Posted by MIGGZ View Post
    Yeah, its a little small but I only plan to run it occasionally (hence the switch) and hoping using the smaller nozzles won't use it up so quickly... will see how it goes... I will re-evaluate if it turns out the tank is emptying too quickly... it was ideal for where I wanted to fit it :/
    Pretty much yeah... just works off the pressure feed to my boost gauge... into the pressure switch and bingo... 18psi it switches the relay and the pump gets full juice...
    <tuffty/>
  9. #2048
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    elcorecto boss!
    Mine doesn't... I do have a progressive controller but not using it... they are unreliable and not totally convinced that its particularly 'progressive' at all... dual nozzle and maybe a 2 stage system using another pressure switch and a solenoid maybe... but will potentially try a dual nozzle setup depending on how things go with this... I am only after a drop in IAT's... not fussed about tuning for it as the car does alright as it is
    <tuffty/>
  10. #2049
    May 2012
    JHB, South Africa
    1,079
    snap did not even see that! sorry bud
    Mine is healthy
  11. #2050
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    What psi rating is the pump you have?
    I have seen a few that range from 150, 200, 250 and 300 psi.
  12. #2051
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Its a devils own pump... 200psi iirc... the newer ones seem rated higher (300psi)...
    <tuffty/>
    Scullies likes this.
  13. #2052
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    So finally after owning a WMI kit for over 2 years I have actually got it fitted and working...
    First of course I de-blinged the pump and the tank...
    Fitted the pump and made brackets for the tanks... piped it all up and wired the pump....
    Had a leak initially from the tank pipe as I hadn't pushed it home far enough but once sorted all was good...
    Quick test on the way home from Bill's... ambient was 20 degrees... on cruise IAT's sat at 22/23 degrees.... 'armed' the system and gave the car a blast in third to properly load her up... didn't log with VCDS but fired up the 'Torque' app on my sammy S3....
    The 25 deg was from idling while parked up taking the screen shot... you can see the minimum figure of 12 degrees... exactly the result I was looking for out of this... normally IAT's would increase to 30/35 degrees in 20 degree ambient under boost but the results so far are very good... I gave the car another burst and had the same result... the car felt strong too... she has felt a little lethargic since the weather got warmer which is to be expected but the WMI appears to be doing exactly what I fitted it for... happy bunny
    <tuffty/>
    ScottD3 likes this.
  14. #2053
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    8 degrees below ambient?! Really? I didnt think it was that good wow.
  15. #2054
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,382
    What water/meth ratio did you use there Tuffty!
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
  16. #2055
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Yeah... its good **** man... when running on the dyno its typical to see it drop below ambient... not as much as this as a rule as it does get hotter on the dyno than it would on the road... will get some logs at some point when I find the time.... meth off and meth on back to back... get a good idea of the actual benefits then..
    Quote Originally Posted by g60leigh View Post
    50/50 currently as Bill had some already premixed... will see how it goes and maybe drop to 30/70 at some point as this would be safer to use if I still get the cooling benefits from it..
    <tuffty/>
  17. #2056
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    I honestly thought it just knocked a few degrees off iats but still ambient or above, climbing with boost. I had no idea it was capable of dropping below ambient on boost. I do remember welly saying his mani wne frosty during winter but thats understandable, and not really good conditions to gauge the gains. Im not sure anybody has documented back to back runs with it on and off, but then ive not bothered to go searching really.
    Up until now ive had absolutely zero interest in wmi...
  18. #2057
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Well... its not definitive by any stretch... but Torque uses the same data as VCDS etc (ECU data from the sensors) and I fired it up when the engine was warm and had done a few miles so IAT's were sat at a realistic 2/3 deg over ambient (which is normal on my setup from previous experience)... Torque records min and peak figures on the dials you have setup and there isn't anything else that would make my IAT drop to 12 deg on a 20 deg ambient day
    I was surprised tbh too... its not to say WMI would do this on any install as its hugely subjective (my hardware setup is quite exotic compared) but I have seen WMI consistently drop IAT's lower than the registered ambient temps to varying degrees on cars run on Bill's dyno...
    No idea why I left it so long lol...
    <tuffty/>
    s3dave likes this.
  19. #2058
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Well done Tuffty. WMI is great stuff, I'm still running a 50/50 mix but I don't have a liquid gauge so haven't really done much logging. All the logging I did last year was on VCDS and on a partially working WMI kit. I really should do some more logging.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  20. #2059
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Agreed, after a few teething issues mine is faultless now and I can tell real time that its working, having the switch just by the steering wheel....
    Mougge likes this.
  21. #2060
    Westy's Avatar
    Dec 2008
    17,264
    I started with a switch but ditched it. My car relies on the WMI so I wouldn't use te switch anyway.
    S3 Build Thread
  22. #2061
    Aug 2010
    bradford
    1,252
    Great stuff tuffty carnt wait till mine is done Saturday coming.
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
  23. #2062
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,382
    I really need to get back on with my wmi set up. Tuffty you are a inspiration LOL
    2001 S3 (AMK)
  24. #2063
    Westy's Avatar
    Dec 2008
    17,264
    I really need to get back on with my wmi set up. Tuffy you are a inspiration LOL
    An inspiration lmfao! It took him 2 years to fit it...
    <tuffty/> likes this.
    S3 Build Thread
  25. #2064
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,382
    Quote Originally Posted by Westy View Post
    That's why I LOL'd it
    2001 S3 (AMK)
  26. #2065
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    WOW that's impressive. Did you put ice water in the 50/50 mix
    Is that just on the small single nozzle setup?
    So you running wmi on the current map?
    Does wmi not throw out the fine tuning of a BT file?
    Are you going to map the wmi in or just run it as you need it?
    sorry for the 20 questions
  27. #2066
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    answers in CSV format...
    No, Yes, Yes, No, B
    <tuffty/>
  28. #2067
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    That looks awesome dude! Love it!
  29. #2068
    RIP S3dave
    May 2004
    nr Glos
    7,139
    <tuffty/>
    lol
    <tuffty/> and Gizmo20VT like this.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  30. #2069
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Interesting day out today... went the TT Forums North vs South dyno day at Powerstation...
    Bill took the Lupo of course :D
    In preparation of course I cleaned the car... she was looking pretty damn good despite my somewhat epic fail of over wet sanding the **** lacquer job from the 'warranty' paint work I had done...
    Over did the bit where the lacquer had peeled away from the original paint and broke through
    ...so for now I have just slapped some touch up over it and will address it later... despite that the rest came up fine.... ah well
    Still she came up ok in the end...
    Anyhoo... back to the dyno day... I hadn't intended to run my car but after a little badgering from Hollie and Bill (no pun intended) I ran her up...
    The runs on Powerstations dyno are very long... seems the dyno puts a lot of load on the car as the poor old girl was glowing a good one... for what ever reason they ran the car again and sadly this lead to the coolant hose behind the turbo decided to let go and piddle coolant over the glowing hotstuff... this lead to loads of white smoke and a small fire on the downpipe... marvellous!!!
    The pipe in question is a stainless hard pipe but has a high pressure heat resistant rubber section to join the two halves together... (right of the picture below)
    Not an easy fix and topping up with water just poured out the bottom again... brilliant!...
    Thankfully Bill being the super hero that he is donned his Badger Man outfit and came to the rescue...
    Hopefully should be a case of remove driveshaft and downpipe and I'll have access to sort it out...
    Cars... gotta love um and todays lesson is (the same as all the others tbh)... heatshielding, heatshielding, heatshielding... anything that is likely to melt probably will
    Engine will be out soon for 'some work' so I am going to address some of the issues like this to up the reliability factor...
    <tuffty/>
  31. #2070
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,254
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Nice little write up but shame about the ending
    I know this probably isnt the best comment....but the pic of bills S6 towing your S3 on the back of a trailer- both in silver is pretty cool looking If anybody saw it on the way home they would have just thought it was on its way to a track day!
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
  32. #2071
    RIP S3dave
    May 2004
    nr Glos
    7,139
    big audi, little audi... lol
    bill@badger5.co.uk
  33. #2072
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    664
    Aint much lucky there man!
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
  34. #2073
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,454
    I bet the S6 doesn't even feel like its pulling anything, That reminds me?
    Does the S6 have the same engine as the S8?
    You could do this Bill
    Trains part 1 - Top Gear - BBC - YouTube
    National Badger5 Rail
    kwistof and StaceyS3 like this.
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  35. #2074
    RIP S3dave
    May 2004
    nr Glos
    7,139
    yes same 4.2ltr v8 engine
    bill@badger5.co.uk
  36. #2075
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Got the car on the ramp today and as suspected it was the rubber joiner... looking at it now I am thinking 'why the hell did I do that!' but you live and learn... irony being if a customers car came in like that I would most likely point out that its not a very good idea lol...
    New bit of hose this time with extra heat protection...
    ...and finally (when everything has cooled down after the leak check) a bit of ceramic backed stuff...
    This of course is a sort term fix... I am under no illusion that I need a full hard pipe there and thats what will happen (plus some other planned tweaks) when the engine comes out for 'some work'
    Moral of the story is never to under estimate how hot these things get and heatshielding plus other preventative measures are your friends
    She is leak free now at least and shouldn't have this issue again before the engine is out... yay!
    <tuffty/>
    kwistof, StaceyS3 and burns3 like this.
  37. #2076
    Westy's Avatar
    Dec 2008
    17,264
    Good work Paul. Very unlike you that rubber pipe! Sort of thing is do lol.
    S3 Build Thread
  38. #2077
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Seemed a good idea at the time and I did heat shield it... in fairness its lasted more than 12 months but Powerstation runs are epically hard on cars... things were glowing big time... relentless mani's would melt lol...
    <tuffty/>
  39. #2078
    RIP S3dave
    May 2004
    nr Glos
    7,139
    <tuffty/>
    Hell yea!
    bill@badger5.co.uk
  40. #2079
    burns3's Avatar
    Jun 2011
    223
    Heatshielding, heatshielding, heatshielding lol, yeah you made it clear to me i needed some
    Booooooosting just a little bit
  41. #2080
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,366
    Love the picture of bills s6 towing your s3 .......... Mint! Only better would be if bill had badger break down assist graphics on it! :-)
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
Tags for this Thread
