JMB RetrofitsBadger5
Results 1 to 13 of 13
    alp a3
    Jun 2009
    just out side of london
    59
    bmc or pipercross induction kit
    Hi I am thinking of getting a induction kit on my a3 1.8t but don’t no what one to pick, bmc or pipercross viper induction kit, what do you lot think, and are the power gains that much. thanks
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    no power gains at all what ever filter you get, so id go for the cheapest option as it wont really matter
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Hi ALP A3, as kev said, you don't get any power gains from an induction kit, the only thing you get is more noise. If you really want to get one though i'd get the BMC and get a cold air feed attached to it
    alp a3
    Jun 2009
    59
    thanks mate il go 4 one of them
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    are there really no power gains to be had? on some cars you can get a bit more bhp released with an induction kit?
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    i dont see the point trying to cool down air before it enters the turbo really, just a pannel filter is enough to aid flow as by the time the air hits the turbo its going to be hot anyway your much better off cooling the air temps after the air has past through the turbo and on its way to the engine imo
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Quote Originally Posted by jdas03 View Post
    True, with some cars you can gain a small amount of power, but the S3 stock air filter is good for up to 300bhp so no real need for an induction kit other than gaining more induction noise, other cars can benifit from induction kit's but not the S3.
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    ok thanks for clearing that up, was thinking of spending some money getting one because its normally the cheapest wat to squeeze some extra power! but with no gains i wont bother! thanks for saving me the cash :-)
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    This brings up the question, what is the cheapest and easiest way to get a little bit more power?
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Quote Originally Posted by landopanda View Post
    Use 99 ron fuel, Shell V-power or some tescos sell it.
    Might add an extra 1BHP lol
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    on a standard car (by standard i mean even chipped) it will make no difference whatsoever. replacing the filter for a standard new paper one will prob make just as much of a difference.
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    Jul 2009
    In a land far far away
    35
    I have a BMC with cold air feed on order for the weekend, only picked up the A3 on monday night, will see if there is anything to gain, apart from any gains it looks a little better under the hood also!
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    You'll gain the induction noise. Like already said, with a good cold air feed you MIGHT gain an hp maybe - but if you just stick one on without an air feed then you'll actually lose power because of the heated air that you'll be dumping into the engine.
    Best "bang-for-buck" is a chip. An induction kit to me is like the relocated DV mod - something to consider when everything else you wanted to do is done and your just tinkering.
    Getting a cold air feed and maybe creating a good heat shield could be a fun project when you've nothing left to do?
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
