Sky InsuranceJMB Retrofits
    May 2006
    Lancs
    211
    Boot catch problem
    Just been out to the car to get something out of the boot and now it wont catch. The electronic mechanism is working when I press the key but the metal claw in the catch wont stay down, even if I push it down with manually with the boot open. Any suggestions?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    This happened to me a while back. I removed the unit to check the mechanism within. Part of it had rusted. After some manual effort moving the peices and some lubrication it has been fine.
    Sanj's Avatar
    Blue Beast
    Nov 2008
    174
    This also happened to me when i bought my car, i sprayed a load of wd40 on mine and it loosened up.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    If the latch still plays up it's just as easy to get a whole new latch unit, the microswitch in mine went and would show on the display that the boot was open when it was actualy closed. The whole new part was only 28 for my car and a easy job as I managed it!
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    May 2006
    Lancs
    211
    Seems to be fixed for now. Took it in bits and the two plastic parts inside weren't working together to hold the latch in place. A bit of messing with a screwdriver and some WD has solved it. If it returns I'll probably just replace the actual latch section.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    The part number for the new boot latch on my car is: 8p3 827 505 hope that helps if anybody else has the same problem.
    Cheers Matt
    2002 S3 REVO
