JMB RetrofitsAH Fabrications
Results 1 to 14 of 14
    Jul 2009
    37
    Best way to find out power gains?
    Whats the best way to find out my actual power gains on my audi s3 which i bought just over a year ago. I asume i have to take car to a specialists etc, is this costly?. And where do i start looking. Live not far outside glasgow.
    I have been told car has
    REVO remap, taking it to 265 bhp
    And it also has a BMC carbon filter and a forge recirculating alloy dump valve.
    Any help is well appreciated
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    The only way you will find out the true BHP of your car is to get it on a rolling road...and get a print out of the power your car is producing.
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    Rolling Road is the obvious answer.
    But you can also do it via VAG-COM - if you have access to it - by logging certain blocks and then transferring to MS Excel. There are spreadsheets available on the web that are already set-up to do this, think it's called "butt dyno" or something. Some say it's more realistic / accurate, because you're doing the runs with correct air flows etc - but you'll need a very long and quiet road to do it - remember, stay safe!!
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
    S3fan's Avatar
    Kiteyboy
    Aug 2008
    366
    Evo - May 2002 "...For keen drivers, the revised S3 is currently the best car Audi makes."
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,920
    Jul 2009
    37
    much would it cost to have car tested on rolling road
    Jul 2009
    37
    any rolling road in glasgow for s3 quatro?
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    Vagcom works it out from various signals from various sensors..... personally id be finding a specific type of rollers (cant rem the name of them) as a lot of rollers really dont tell the full story..... throw in your haldex and your left with an even bigger problem to identify the power
    no help im afraid, we're all in the same boat
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    To get a true reading then you need a engine dyno
    Rolling roads are not the most accurate when it comes to true figures
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    knew someone more experienced would pop up, cheers Andy
    Jun 2009
    Leeds
    3,472
    Put my old ford engine on one
    more details here
    http://en.wikipedia.org/wiki/Dynamometer
    One in action, it gets good at 1:20
    FOR SALE
    S3KO4's Avatar
    Aug 2009
    London
    850
    doubt 265. I have stage 2 with all the mods, and only getting 263
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    u still need the FMIC mate
    May 2010
    West Sussex
    157
    All RR differ, some over read, some are pretty much spot on (which usually leave the owners upset)
    What I used to do was to get a RR figure before I start modding & during so then I can see what difference the mods have made. A RR can give you a rough idea, it really does depend though. I think some RR will have to pull the Haldex fuse to do the runs...
    I think Thor have a better way of doing things with hub dyno's but as said above, bench dyno is the only way to get a true figure without fudge factors.
    Ebony black 99 S3, Forge 007, cone filter, goodridge braided lines, apex lowering springs. More to come...
