AH FabricationsEM Tuning
Results 1 to 24 of 24
    Dec 2008
    40mm Drop with new wheels
    Hi all,
    Ive just fitted a set of rs4 reps from rimstyle on my a3 1.8t, and they seem to sit quite far out. This looks good and im not complaining as it save the need for any spacers.
    However, I want to lower it 40mm now on shocks and springs, and am a bit worried that they might rub on the arches? I wanted to go 40mm as I have done some research and this seems to be the right drop for my car, so wondered if anyone else had dropped 40mm on rs4's from rimstyle!?
    I suppose tucking the wheels slightly could be an option??
    All help accepted!
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    Are they 18's? If so you should be fine with a 40mm drop and I'd suggest the Weitec Ultra GT as a really good option.
    https://www.dpmperformance.co.uk/wei...96-p-1451.html
    Damian @ DPM
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Dec 2008
    Yeah they are 18's.
    Do you have any slightly cheaper kits Damien? Looking to spend maybe 250-300, however if thats gonna savage the ride quality I will look to spend a bit more.
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    i can personaly rate that kit as ive got the same one with my RS4 Reps and got it from Damian too. Get that kit, money well spent in my book
    Audi A3 1.8 Turbo, Wietec Ultra GT 40mm kit, 3" Full Custom Stainless Steel Exhaust, Custom Code stage 1 remap, 17" RS4 Alloys, Whiteline ARB
    Dec 2008
    Your car looks hench so will definately consider it =D
    Where were your reps from? I presume most of the reps out there must come from the same place, did you find them close to the outer arch in width?
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    My A3 1.8T is on a Wietec Ultra GT kit (40mm) and running 18" RS4 reps and its spot on. No clearance issues at all :D
    The offset on my wheels is ET35 FYI.
    Here's a pic...
    I'd suggest he Wietec kit also, its quality.
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    Yeah we have the JOM and Koni but in my opinion the Weitec is worth the extra.
    https://www.dpmperformance.co.uk/jom...96-p-1182.html
    https://www.dpmperformance.co.uk/kon...96-p-2270.html
    Damian @ DPM
    DPM Performance
    T: 01207 561606
    Aug 2004
    526
    Quote Originally Posted by A3Tom View Post
    Here's a pic...
    T
    That looks good. What's the ride like on the Weitecs? Compliant? Harsh?
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    Quote Originally Posted by drivebycar View Post
    Hi all,
    Ive just fitted a set of rs4 reps from rimstyle on my a3 1.8t, and they seem to sit quite far out.............and am a bit worried that they might rub on the arches? ........
    Got any pics?
    I'm hopefully ordering some wheels from Rimstyle in the next day or so - if the buggers would just answer my e:mail / pick-up the phone that is!!!
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Quote Originally Posted by DPM View Post
    Damian @ DPM
    comeon damian your the pro here, its the offset that effects the position of the wheel in the arch you need to check the offset on the inside of the wheel or inside where the hub centre goes if its anywhere near et35 then there be fine with a 40mm drop
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Yep, as has been said you need the right offset and ET35 is spot on for a 40mm drop.
    The ride on the Wietec is fine, its the 18's that make it feel harder than it is though!. When I ran my standard wheels the ride was just as smooth as standard with the Wietec kit on
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    a couple pics of mine on the same Kit.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    Quote Originally Posted by s3_kev View Post
    I already know that the Rimstyle RS4 reps are ET38 so I just needed to make sure he hadn't went for 19's as you may get some rubbing with the 40mm kit but he's went for 18's so all is good.
    Damian @ DPM
    DPM Performance
    T: 01207 561606
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    Here's a pic...
    T
    Tom the alloys look perfect and the ride height! Looks like good deisgn!
    Dark Vader Half sibling - MyThread
    Jun 2009
    Kent
    311
    Guys, bin the mud-flaps - please!!!
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by IIIadidasboy View Post
    If you want to follow me around and clean all the crud off my nice clean paintwork that these wheels flick up then we have a deal
    ROLTYA3TURBO's Avatar
    essex boy :)
    May 2009
    essex, uk
    247
    just to throw another option in!
    how bout the kw 40mm all round kit?fitted it to my car at the weekend,seems to be bedding in nicely,haven't driven it much lately but from what i can tell its a really improved ride!
    not harsh at all yet still very responsive and much more sporty,i love it!
    still want to order and fit the kw arb's to go with it will have to wait a week or 2.
    i'll upload some pics in a few days once the setup has bedded in more
    '98 azure blue a3 1.8t, forge 007p,KW 40mm springs/shocks,18" polished rs4's,s-style chrome mirros,black diamond front 20 groove discs,ebc greenstuff pads,painted and decal'd calipers,colour-coded engine cover,aero wipers,chrome indicator bulbs,l.e.d xenon sidelight bulbs,h.i.d xenon headlight bulb kit,let the work begin!
    Latest addition - s style chrome mirrors
    Next up - remap,exhaust
    Jun 2009
    Kent
    311
    Eeeerrrrrrrrrrrrrrr.........
    Jul 2009
    hi. Do you know if these rs4 reps are still on rimstyle as I cant find them? thanks
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Not sure, you can get them a lots of other places though
    shanejess
    i have 19" RS4 rep on my S3, ive had them for 6 weeks, it hadnt been lowered until today, it failed its MOT on tuesday because of both rear springs, so perfect oppertunity to have eibach springs fitted it looks and drives superb, im having my original wheels beadblasted and sprayed and at least 7 coats of laquer, they should be ready for next week hence my repicas very neary band new for sale.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    My wheels actually pertrude the arches ever so slightly at the front but tuck in quite nicely on cornering... mine is lowered about 40mm, maybe a little more and i've had no problems
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    Keeno's Avatar
    Spooly Spooly Boosty Boosty!
    Apr 2009
    West Sussex
    695
    Been looking for some for ages, where'd you get them from?
    Main dealer only?
    Cheap and Reliable is not Fast. Cheap and Fast is not Reliable. Fast and Reliable is not Cheap!
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by Keeno View Post
    Main dealer only?
    Stoke Audi on Ebay
    T
