Chris NottSky Insurance
    Oct 2008
    Aberdeen
    10
    Battery Warning Light
    Early last month after coming back from a week long business trip, the battery in my A3 1.8T was completely dead so I got it fitted with a new battery and went on a short drive.
    I had to go away again on business the next day for a month, and got home at the weekend. When I took the car for a drive, the battery warning light remained on (static, not flashing).
    My first thought was that the alternator must be goosed, but wondered if the battery change could possibly have something to do with the warning light instead? Has anyone experienced anything similar?
    Dansmith's Avatar
    Apr 2009
    Bournemouth, United Kingdom
    459
    Did it start first time? if so I just had my battery changed in my s3, I had to have the ECU re-set! I think you will need a VAG com mate!
    If it didn't start then alternator is the next port of call!
    Bignick's Avatar
    Jul 2008
    Kent
    165
    I've never had to re set anything apart from the windows when taking the batery out.
    The light that burns twice as bright , burns half as long.
    Jun 2009
    North Cornwall
    171
    Sounds very much like alternator. Easily tested with a volt meter. Run the engine and look for 11-12v(ish) across the two terminals.
    Oct 2008
    Aberdeen
    10
    Yep, pretty sure it's the alternator now, got hold of a volt meter last night and that confirmed it for me.
