Chris NottAH Fabrications
    Jul 2009
    cd/radio dead but backlight always on?
    Hi everyone
    I have an audi a3 2002 plate. My radio/cd/tape in the car is not working. The backlight on the display is lit up but nothing is shown on the display, and no tapes/cds play, and the radio doesnt tune.
    Also when I try to turn the radio off the backlight is still lit up. Even when i turn the ignition off and remove the key the backlight is still lit up.
    Can anyone advise or has anyone had a similar problem?
    Thanks in advance
    Ben
    Jun 2003
    World of my own
    9,813
    Sounds like the HU is getting the trigger from CANBUS to switch on but doesn't have the live feed to do so. Have you checked the fuses, there's one in the fusebox and also one on the back of the HU.
    Alex Turner
    Jul 2009
    cheers, i have fixed it! it was a fuse issue that fixed it but weirdly the fuse wasnt blown. how i did it:
    1. open the fusebox (which is on the driver side dash, hidden until you open the door. jemmy up the lid to reveal it)
    2. consult the handbook and remove the relevant fuse
    3. put the fuse back in
    4. the radio resets itself! all you then need to do is plug in the security code for the symphony radio
    hope this helps someone else!
    ta
    ben
