Chris NottEM Tuning
Results 1 to 7 of 7
    nath-w's Avatar
    Mar 2009
    134
    My S3 is playing up again!!!!!!
    for some reason all of a sudden the s3 has decided to start playing up again. its nots a major problem but for some reason when im driving it reasonably hard, by this i mean changing gear 4000 rpm plus, its starting revving up as i change gear. So by this i mean soon as i let off the gas and put the clutch in, the engine will rev itself up another 1000 or so rpm, its making it sound like i cant drive. Does anyone know what this could be??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Sounds like the common clutch switch problem.
    <tuffty/>
    nath-w's Avatar
    Mar 2009
    134
    Is this an expensive problem and hard to do???
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    IIRC it just requires changing the switch, not done it myself but pretty sure there are a few threads on it if you have a quick search.
    <tuffty/>
    Jun 2009
    North Cornwall
    171
    Piece of cake to replace and only costs around 12.
    It sits up underneath the drivers footwell, its just a switch with a plunger mechanism on the clutch pedal arm.
    Firstly tho, before you replace it, just make sure the one you have is actually broken.
    With the clutch depressed, you can slide the plunger back out again and that may solve it. The other thing is to make sure the switch is actually being pressed in by the pedal arm.
    Failing that its pretty straight forward to replace it. You can do it without removing the cowling but its alot easier of you take it off or loosen it.
    Jul 2009
    Cambridgeshire, United Kingdom
    427
    nath, did this solve the problem? Just wondering as I have the same thing and it didnt solve mine.
    Current
    Porsche Cayman S
    Gone but not forgotten
    Audi S3:Blueflame TBE; 3" blueflame downpipe; Forge 007p; jabbasport custom map; Badger 5 TIP v1, various bushes, N249 Bypass, Stack Boost Gauge, Junior GT Brembo brakes, tarox 2 part discs, DS2500's
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    So you've changed the clutch switch?
