Sky InsuranceVolks Autos
Results 1 to 32 of 32
    ROLTYA3TURBO's Avatar
    essex boy :)
    May 2009
    essex, uk
    247
    Post Painting Engine Cover
    Hi guys.I have now sprayed my engine cover and thought i'd do a little write-up about it to share some knowledge in a step by step guide so you can have a gander and maybe get some inspiration if your looking to do this yourself.
    Right!
    Well first up obviously go to your car, lift the bonnet and remove your engine cover.On the a3 1.8t there is 4 screws located at the top just pop these out and your done!
    Before cleaning/degreasing your cover make sure you remove the 4 screws and also the rubber grommets from the cover (use a small flat tool to pop these out) to get right in the nooks and crannies.
    Clean your cover with a SUITABLE degreaser.Obviously no strong acids as the plastic WILL melt, a motor oil/mechanics degreaser or white sprit/turps is fine, it's only to remove the strong bedded in oils and stains.Rinse off and allow to dry.
    Once that is done, i used a regular (not too abrasive) sandpaper to rough over the cover and remove some of the grain pattern.
    And you end up with something like this
    Next i rubbed over the cover a few times with 240 grade wet and dry paper with soapy water (cleans the surface aswell as lubricating the paper) to take out the rough spots left by the sandpaper just to allow a smoother surface.Rinsed off with clean water and allowed to dry.
    Once dry I then wiped the cover over with pre-paint to get rid of any residue left by the sanding process.
    Then mist a coat of filler primer over the cover to fill in any grained pattern and allow to dry for a few minutes, then apply a second coat.
    1st coat
    2nd coat
    dried before being wet sanded
    Right,well after allowing to dry for a couple of hours i then used the same 240 grade wet and dry paper with some soapy water and gently smoothed the cover over.
    Then i set about masking up my spray area in my dads shed lol so wherever your spraying obviously mask up everywhere as you don't want paint all over the shop!
    Once your set up use some more pre paint with a clean cloth and wipe the area to remove any dust.
    Then place your cover in your spray area and apply 2-3 coats of normal primer.I used white primer, as the colour i chose to spray my cover with was the metallic blue that my car is painted so it'll make it "pop" more.Like for like if you choose a dark colour use a dark primer,light colour light primer.
    Left out in the sun to bake hard for an hour
    Then i wet sanded the cover with some lighter grade 600 wet and dry paper with the soapy water and left to dry.
    I then applied a mist coat of colour before applying the second coat around 10 minutes later.Left to dry
    Again i used some lighter grade 800 wet and dry paper to remove any unsmooth paint.left to dry
    Wipe over the cover with pre paint and wait a few minutes to dry.
    I then sprayed on another 2 heavy coats of colour this time allowing around 15 minutes between coats to get a good coverage.Left to dry.
    Wet sanded and left to dry again before wiping over with pre-paint.
    I then sprayed on 3 coats of clear laquer allowing 10 minutes between coats and left to dry for 24 hours.
    At the end you will end up with something that looks like this
    Originally after spraying the colour i was going to mask up the audi rings and the 5v turbo emblems and spray them in silver or white but after spraying over with the blue i really loved the "stealth" look of it so i'm keeping it like this
    I hope you enjoyed reading this and hopefully i have given you all some ideas!
    Thanks for looking,if you have any questions just pm me and i'll be glad to help
    '98 azure blue a3 1.8t, forge 007p,KW 40mm springs/shocks,18" polished rs4's,s-style chrome mirros,black diamond front 20 groove discs,ebc greenstuff pads,painted and decal'd calipers,colour-coded engine cover,aero wipers,chrome indicator bulbs,l.e.d xenon sidelight bulbs,h.i.d xenon headlight bulb kit,let the work begin!
    Latest addition - s style chrome mirrors
    Next up - remap,exhaust
    Jun 2009
    1,064
    looking good. ill do mine soon i think! how much did it all cost (around)
    Its gone replaced with a mk2 golf gti 16v :D
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,607
    thanks for sharing
    the last three pics are not as good as the rest,did you run out of film for the camera
    wnjuk's Avatar
    Sep 2007
    High Wycombe
    107
    Excellent write up
    Merlin Purple 1998 Audi A3 1.8T Sport, 17" TT rims, facelift lights, facelift seats, TIP, Chipped UK Remap, Forge diverter valve, 312mm Brakes & Projektzwo bodykit.
    essex boy :)
    May 2009
    essex, uk
    247
    Quote Originally Posted by emery1990 View Post
    roughly around 40-45 for filler primer,primer,2 custom body colour match spray cans, can of clear and a few sheets of sandpaper,i only done it for something to do really lol but glad i did now
    essex boy :)
    May 2009
    essex, uk
    247
    Quote Originally Posted by voorhees View Post
    thanks for sharing
    lol they was all taken on my mobile believe it or not,i'm in the market for a new digital cam soon so once it's back in the bay i'll get some really nice shots of it
    essex boy :)
    May 2009
    essex, uk
    247
    Quote Originally Posted by wnjuk View Post
    Excellent write up
    cheers fella!
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    Great finish - I haven't got the patience to go through all those steps - well done!!!
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Good work there, looks like a proper job.
    Tempted to do mine in Gloss black now...might be a job for rest days next week.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    whats wrong with the std black nice and clean ????
    nice job but not for me ......
    red to red black to black blue to bits
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    i say ditch the engine covers completely and paint/power coat the inlet manifold and rocher cover and get some nice clean new stainless nuts and bolts...mkaes it look like an actual engine and not a bay of plastic.
    Good job on the cover though... looks like you got a really good finish. There is really no other way to do it than to spend alot of time with alot of coats. good job
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    Bignick's Avatar
    Jul 2008
    Kent
    165
    Nice job and excellent write up, you could do your rings with a silver pen, but that would seem a bit cheap after all your effort.
    The light that burns twice as bright , burns half as long.
    essex boy :)
    May 2009
    essex, uk
    247
    thanks for the comments lads.i really only done it because i had a few days off work and i was kinda bored waiting for my suspension to turn up lol.
    will definantly be considering painting the inlet manifold,and other bits and pieces in the future with all new nuts 'n' bolts to freshen the engine up
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    I'm in the process of doing mine at the moment....lots of waiting around between coats and lots of flatting
    I'm going for gloss black on mine to keep the OEM look but making it a bit more tidy at the same time
    T
    ghost.s3's Avatar
    Apr 2009
    Cape Town
    65
    Nice job dude - looks great . Wish I had the patience to complete a job like that. Would be great to see it once it's been put back in the bay.
    2001 Mineral Grey AMK
    essex boy :)
    May 2009
    essex, uk
    247
    Quote Originally Posted by A3Tom View Post
    T
    it's all worth the effort though
    essex boy :)
    May 2009
    essex, uk
    247
    Quote Originally Posted by ghost.s3 View Post
    once i get a bit of time and remember to do it i'll take some pics
    will 90% be at audi's in the park too so no doubt they'll be pics of it somewhere,that's if i get the nail polish on the paint sorted out
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,639
    Excellent write up dude and looks like a top job...
    Well done mate.
    Tom, get some pics up when you have done yours too mate
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by nilz18t View Post
    I will do mate.
    I've sanded, filled, sanded, primed, sanded, primed, painted, flatted, painted, flatted, cleared, flatted and cleared again and now I'm painting the Audi rings and writing before I give it another flat back and a couple more coats of clear. I wouldnt have bothered putting clear on before painting the details as I was going to leave it totally black....BUT I changed my mind as it made the engine bay look really dark.
    Its not totally smooth but its certainly looking a lot better than it did when it was stock....nice, clean and glossy. I've also done the small perforated one that sits at the front of the engine where the dipstick goes through.
    On another note Nilz, your mate that came to Cov with us that night....does he work at Halfords?. When I was picking up my paints etc I'm sure I saw him hanging out of a Saab fitting something in the carpark.
    T
    Feb 2008
    2,810
    tom mate when were you in cov?
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by S3 Rav View Post
    Must have been about 5 weeks ago now I think, maybe longer. I popped over with Nilz one Wednesday night for the meet by the Ricoh.
    T
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Here's now it is so far (excuse the state of it, covered in dust and fingerprints!)
    essex boy :)
    May 2009
    essex, uk
    247
    looks good tom, well done fella!
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Its a right ba$tard doing the details on it though.....wish I hadnt bothered now!.
    The silvers alright but the reds a right bugger to get smooth so I'm just putting loads of coats on so I've got enough paint on there to flat it down when its gone fully hard.....MISSION!.
    essex boy :)
    May 2009
    essex, uk
    247
    that's kind of why i didn't bother doing mine, plus i like the stealthy look mine has with the emblems the same colour, plus i think i'll be throwing it out of the bay in the future to paint the rocker covers
    have fun with yours, takes ages i know lol
    Nilz's Avatar
    Apr 2006
    9,639
    Yo that looks good dude!!
    Yea thats my cousin, he works there, is one of the audio specialists there.
  28. #27
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Cheers!, I just want to get it back on the car now as I'm fed up of doing it!
    I thought it was him, he was under a gazeebo in the carpark buried in the footwell of a horrid turquoise Saab .
  29. #28
    Nilz's Avatar
    Apr 2006
    9,639
    Cool, so as soon as you have done that, and have done such a good job of it, just let me know when I can drop mine over to you
    Yea he has his head under all sorts of cars that come into there....lol.
  30. #29
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Well I've flatted everything back so its super smooth now so just need to lob a couple of coats of clear on it in the morning.
    Its taken an age so I wont be doing any more!!!!
    T
  31. #30
    Jun 2009
    Kent
    311
    Boys - we still need pics of them back in the bay!!!
  32. #31
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by IIIadidasboy View Post
    Just got to put another coat of clear on it and give it a polish
  33. #32
    essex boy :)
    May 2009
    essex, uk
    247
    finally got round to putting my cover back on the engine so took some pics of it earlier as i was taking some shots of the car in this lovely weather we have today!
