AH FabricationsEM Tuning
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Seat Airbag Fault?
    Hi.
    Posting for a mate.
    He's just pulled up fault codes...
    01044 first control module incorrectly coded intermittent
    00656 seat occupied passenger side intermittent
    Has anyone had this? There's not much on Google search really. Found mention of Sensor G128 which appears to be a pad in the seat upright somewhere that can come unstuck and fall off??
    He knows about the connector under the seat (had that problem before) and that's fine.
    Anyone please??
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    Dansmith's Avatar
    Apr 2009
    Bournemouth, United Kingdom
    459
    Quote Originally Posted by NineNails View Post
    Hi.
    Posting for a mate.
    Anyone please??
    Si.
    Is the fault intermittent or not?
    I get it with mine and it seems to be a problem with the switch that turns off the passenger airbag or the warning light of the airbag being off (above your head)
    still havn't managed to fix it but its so intermittent it doesn't really bother me!
    NineNails's Avatar
    Sep 2006
    North Wales
    577
    I suspect yours is a different fault, He doesn't get the overhead airbag light, it's the main warning one on the instruments that lights and when it's on it's on untill it's reset with vagcom and then comes straight back. Although the code says 'intermittent' it's not because it's all the time.
    The tailgate has just been sprayed and the car has been in an oven...I don't know how hot these get or even if it's relevant, just thought it was worth mentioning.
    Si.
