EM TuningSky Insurance
    May 2009
    Midlands
    197
    S3 on 18" RS4'S, which profile tyres?
    just had sprayed a genuine set of TT RS4 alloys to go on my s3. Now assuming that the rim being 1" bigger than th 17" Ronals, the car on standard suspension will sit higher. my question is do I go for 40mm or 35mm profile tyres. If it helps i will be fitting AP coilovers.
    regards
    Ben
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    The 35 or 40 in the tyre size isn't mm, it's the % of the tyre's width so the difference is actually more than twice what you'd imagine (but still only ~11mm). The decision should be based on how wide the wheel/tyre is you're fitting, or what tyre you're after. I got 225/35 R18s for my RSTTs simply because I wanted F1 Assyms and they were in stock.
    I wouldn't say it's likely you'll see or feel any difference in the 1cm ride difference... there's more range between under/over inflated tyres.
    Got them from www.camskill.com, if you're interested.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    May 2009
    Midlands
    197
    Yup looking at either 225 35/40 /18's
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    You want 225/40/18 for an S3 mate, to keep the rolling radius as close to standard as possible.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    225/40/18 is what your wanting, just had two fitted today.
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    The width of the wheel Vs the tyre will also play a part - if you want the "stretched" look etc.
    General rule of thumb is that the lower the profile the better the handing - but they'll be "louder" and less forgiving over bumps and pot-holes.
    It's a bit of a balancing act.
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
