Badger5JMB Retrofits
Thread: overboosting?
    Oct 2003
    Wilmslow Cheshire
    336
    overboosting?
    Hiya guys !
    After going to the RR day in Manchester at the weekend my car had a boost gauge hooked up for the first time and on each run it was sustaining 1.35 bar and peaking at 1.5 , similar figures to some s3's that were there. Is this too high because i know that i'll be running a smaller turbo than an S3 - Dont want to run the risk of damaging anything so was wondering if it was worth fitting a boost controller so it can be turned down for day to day use.
    Jimbo [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    Re: overboosting?
    Dude, I thought that the ECU had built in overboost protection? If you boost over a certain amount, it kicks you into Soft Limp mode to avoid damage. Therefore, if you're not hitting limp mode, you SHOULD be within safety limits, right? [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    Anyone?
    Sep 2003
    Manchester
    340
    Re: overboosting?
    Jim, if your not hitting limp mode I wouldn't worry to be honest mate. The only reason I can see for you to get an MBC is so that it sustains the boost for longer periods.
    Like the set up I had, it was shown on the rollers that I was holding higher boost levels for longer than the other cars. The other bonus is that you can put a cap on the boost limit. Mine was capped at just over 1.4bar, which I am happy with for day to day running.
    Could stick it up a little, but I will just get boost spikes (with my current N75 valve) leading to overboost and limp mode.
