JMB RetrofitsChris Nott
Results 1 to 9 of 9
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Removing S3 door mirrors?
    Hi,
    Does anyone have a guide to removing the door mirrors on an 8L S3/A3? I need to change the casings and would like to understand the procedure before I crack on
    Cheers,
    Dave.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Darren4's Avatar
    Feb 2009
    Surrey
    186
    If your talking about taking the whole mirror of the car, it just a case of popping out the old a black triangle cover thing inside the car and undoing a bolt.
    It's quite a big bolt so you'll need a big allen key bit
    HTH
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Thanks Darren. Which way do you pull/push the interior clip? I'm conscious of snapping something and it not reffitting correctly. The car currently has no rattles, so I don't want to introduce any.
    > S3 225 (03) - OEM+
    View: My S3 diary
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    I'd be interested in any guide that may be lying around - thinking of taking mine off and spraying them black - unless of course anyone knows of a better way (covers?) of doing it.
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
    ruairi83's Avatar
    Dec 2007
    739
    lads pop glass out. when taking out take it easy as they my be heated and need cables taken off mirror glass.
    Two screw on motor take off.
    Two/Three screws on mirror base plate and you have your wing mirror base plate off and can spray ro replace...
    Jun 2009
    Kent
    311
    Quote Originally Posted by ruairi83 View Post
    .......Two/Three screws on mirror base plate and you have your wing mirror base plate off and can spray ro replace...
    Cheers ruairi, is that from the outside or inside though? - I thought it was going to need the internal trim off to do it?
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Heres a guide i found off www.a4mods.com
    Before AfterI picked up a set of Matte finish In.Pro mirrors from a group buy on AZ a while ago. I just got around to doing the writeup on the install. The process is very easy and should only take 20 minutes. You have to be careful tough, because you coudl break some of the platic tabs during the process.
    SUPPLIES -The supplies are easy: The mirrors, and some basic tools (screwdrivers)
    First thing you need to do is remove the mirror itself. To do this just point the mirror to the floor using the interior controls. When you get enough room to fit your finger behind it, place your finger there and pull it towards you.
    There are about 3 clips which hold it in place. Do this carefully as to not break the clips.
    The mirror will pop out as pictured to the right. You will then have to disconnect the two electrical connections on the rear of the glass. The next thing you want to do is take your screwdriver (I believe it was a phillips head) and unscrew the two screws located at the bottom of the mirror housing
    With the above two screws removed, position your hand like pictured to the left, and press down with your thumb where the arrow points.
    You will feel the bottom of the housing pop out in the middle
    Work your way around the bottom edge of the housing until the bottom piece disengages. With the bottom portion removed, you have to lift the housing upwards to disengage it. It was easiest for me to start at the section closest to the car.
    This part WILL require PATIENCE...you will probaby feel like it wont come off, but be CAREFUL and keep working with it....it will come off.
    The installation of the new mirrors is just the same in reverse.
    Final pics:
    My Much Missed :Imola Yellow S3 - Revo stage 2, SPS3, RS6 reps, Pirelli P Zero Rosso, Cupra R splitter, Brembo's, 323mm EBC Turbo Grooved Discs, Ferrodo DS2500 Pads, Forge DV, Forge FMIC, Fidanza Aluminium Flywheel, Sachs Clutch, Green Cotton Dynatwist induction kit, 3" Downpipe, sports cat, Milltek cat back, Bilstein B8's, KW rear adjustable tie bars Whiteline Adjustable ARB's, Eibach Springs, Powerflex Bushes, Bose Concert System
    Now : Cupra R 225
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Thanks indiemike, very useful guide
    > S3 225 (03) - OEM+
    View: My S3 diary
    Jun 2009
    Kent
    311
    Thanks for the guide link Mike - quite an interesting site - with some good ideas!!
