Sky InsuranceVolks Autos
Results 1 to 15 of 15
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,158
    Changing Coil packs. Is there a guide
    On my drive home last night my car started juddering and the engine light was flashing on the dash. I slowed down and could feel and hear the car missfiring everytime I pressed the gas. Vagcom has picked up the following:
    Address 01: Engine Labels: Redir Fail!
    Part No: 8N0 906 018 BH
    Component: 1.8L R4/5VT 0001
    Coding: 10710
    Shop #: WSC 00000
    WAUZZZ8L021010571 AUZ7Z0A1997702
    2 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16686 - Cylinder 2: Misfire Detected
    P0302 - 35-00 - -
    Readiness: 0000 0000
    Now the Ross-Tech wiki isn't very specific and lists a whole host of possible causes such as:
    Possible Causes
    • Ignition system
    • Fuel injectors
    • Fuel pressure
    • Running out of fuel
    • EVAP canister purge valve
    • Evaporative emission system
    • Low compression
    • Base engine problems
    • Controle Module damaged
    My questions are:
    1. Is cylinder 2 the 2nd one in from the left or the right as you are looking into the engine bay?
    2. What else can I do to determine the cause eg swap coil packs/injectors between cylinders.
    3. Is there a guide (with pics) to change the coil packs.
    4. How much are OEM coil packs (genuine from Audi) and is it worth me changing all 4.
    5. An Audi TT owner at work thought that the coilpacks were all recalled due to a common problem with them and Audi may do it under warrenty!!!!?
    any help is appreciated, cheers guys.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Maz
    Maz's Avatar
    Moon is made of green cheese
    Jan 2005
    East
    1,008
    Quote Originally Posted by Westle View Post
    Just changed all four recently, two of them failed (115 for 4 - Trade price) and have two spares just in case.
    1 = Yes (from the left)
    2 = ?
    3 = 1 & 2 are easy to swap 3 & 4 are a bit of a pain as you need to remove about 5 hex bolts for the part that sits on top of them. (Not sure what that is) but easily done.
    4= They cost anything between 30 - 40 from Audi
    5= There was a recall many moons ago but I'm fairy sure this does not apply any more.
    Theres nothing worse than a limp S3, hope you sort it soon.
    Mineral Grey [
    AMK
    Westy's Avatar
    Dec 2008
    17,158
    Thanks for the reply buddy, I think i'll try and get a coil pack from Audi at lunch and fit it tonight. Are they easy to do?
    The strange thing is that just before it hit limp mode it felt a lot pokier than normal
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,158
    Just incase anyone else needs help changing a coil pack I found this guide
    http://briskoda.net/technical-guides...-engine/76367/
    S3 Build Thread
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    what coil packs have you got fitted ???? Genuine ones are the only way to go and Audi are only a little bit more expensive than places like GSF.
    red to red black to black blue to bits
    Westy's Avatar
    Dec 2008
    17,158
    Quote Originally Posted by fingermouse View Post
    Yeah i've got genuine packs mate. I learnt my lesson last time when I bought a ECP wheel speed sensor that only lasted 2 months before it packed in, the audi one has been solid.
    I've spoken to my local dealer and they have 5 in stock so i'm going to pick one up at lunch then fit it when I get home after work.
    S3 Build Thread
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    I worked on an A4 a couple of days back that was throwing some of those codes.... turned out to be just a faulty spark plug...
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Westy's Avatar
    Dec 2008
    17,158
    I've got the coil pack sitting on my desk in front of me, I'll be fitting it in about an hour so I'll find out then. If the coil pack doesn't fix the problem I'll be getting plugs tomorrow
    S3 Build Thread
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    Hope it works out for you mate
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
    Westy's Avatar
    Dec 2008
    17,158
    All sorted.
    Took 2 mins to swap over the coil pack then cleared the VAGCOM errors. Took for a 20 min spin and the car felt more responsive and dare I say it slightly faster! It may have all been in my head though
    S3 Build Thread
    Jun 2009
    Kent
    311
    That's good to hear.
    I'm suffering from little power dips at the mo, and I'm wondering if it is heat / maf related or electrical. Still waiting for my new VAGCOM lead to turn up, to see whats happening, hopefully it'll turn out to be something like this then - a 2min fix sounds good!!!
    Westy's Avatar
    Dec 2008
    17,158
    2 min fix if you want to replace the coil on cylinders 1 or 2. 3 & 4 are a bit more difficult as you need to remove some gubbins that sits on top!
    VAGCOM is the best thing i've bought for my car. Its paid for itself already in saving on garage diagnostics.
    S3 Build Thread
    Jun 2009
    Kent
    311
    ....VAGCOM is the best thing i've bought for my car. Its paid for itself already in saving on garage diagnostics.
    Yeah tell me about it - don't you find now though, that you actually start looking for problems to diagnose?!!
    Westy's Avatar
    Dec 2008
    17,158
    Quote Originally Posted by IIIadidasboy View Post
    What just to get your moneies worth haha.
    I tend to scan once a month just to keep an eye on things.
    S3 Build Thread
    Jun 2009
    Kent
    311
    !!!WARNING. ALERT!!!
    Thread revival I know.........
    I've been suffering with power dips / hesitancy lately. I can hear the turbo spooling up (more than I recall when the car was new) when suddenly the turbo can go quiet and it almost feels as though someone is applying the brakes - theres no pattern to it and sometimes when its really bad it can bring up the engine management warning on the display.
    Well I finally got my VAG-COM lead and thought this would be the first thing Id investigate . Like Westle before I got very similar fault codes returned, 16684 & 16685 (which is cylinder 1 and not 2) - which obviously have the same possible causes as above.
    Although, missing from that list is the following:
    Air Intake System leaking
    Fuel Supply faulty
    Injector(s) faulty
    Ignition Cable(s) and/or Spark Plug(s) faulty
    Ignition Coil(s) faulty
    Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
    Camshaft Position Sensor (G40) faulty
    Yesterday I cleared the faults and took it for a spin. The car felt really good, which I cant quite understand, but then hour in, the car started to do its thing - maybe not as bad as before and it didnt bring up the engine management warning. So, back in to the pits and I plug in - no faults returned - so I start thinking this isnt a major engine problem and is probably air or electrical related?
    Late last night / early this morning (empty roads) I took it out for a right good blast and I found there actually is a pattern - above a ton, it stops doing it and starts to pull really really strongly - this now makes me think that its actually air related.
    Anyone got an ideas, what other tests, VAG-COM or otherwise, can I do to start narrowing this down.
    Thanks for reading / listening!!!
