JMB RetrofitsVolks Autos
Page 19 of 21 FirstFirst ... 912131415161718192021 LastLast
Results 721 to 760 of 818
Like Tree23Likes
Thread: AH Fab / Ebay / Forge S3/A3 FMIC installs (image heavy)
  1. #721
    AVLO's Avatar
    Mar 2012
    Doncaster
    276
    hi guys i am going to be getting a fmic for the apy s3 very soon, i am planning on going with a hybrid turbo eventually and was just wondering what will be the best cooler to get whilst keeping fogs and oem grills? i was considering ah fabs v2 but was unsure if keeping the fogs was an option with this cooler?
    options??? thanks guys
  3. #722
    Feb 2012
    bedfordshire
    751
    If you read back on this thread all the info you need is there mate and yes the fabs v2 is more then enough and you can save the fogs
  4. #723
    Nov 2011
    Sturminster Newton
    190
    How does this intercooler look size wise
    200791391130
    IC5006
    Bar and Plate Intercooler Corn size: 550mm x 225mm x 64mm
    Overall Length 710mm
    57mm(2.25'')or 64mm(2.5") Inlet and Outlet
    Maximum Pressure: 45psi
    Max Horsepower Capacity : 450hp
    A3 1.8TQS Minge blue
    Mods: AP coilovers, Strut Brace, Merc wheels, S3 brakes, hopefully going BT soon
  5. #724
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I'll get a pic up tomorrow of how it fits.I fitted mine today and its the made a bug difference.it has more torque and just pulls hard.
  6. #725
    phil miller's Avatar
    Sep 2012
    Devon
    843
    i am right in thinking everyone buys the forge boost sensor pipe and how do people get round the DV take off from the charge pipe and the small vac take off? can anyone shed any light on this please?
  7. #726
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I think prawn made a list of everything needed.check his thread.I just got a 90 degree 63mm alloy pipe of eBay.drilled two holes,4mm for the n75 and 19mm for the dv.ill get pics for you tomorrow
  8. #727
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Fitted thus about a month ago,forgot to post pics.
  9. #728
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    Hi guys, quick question.. Found the wellycooler.. Now I see one on the bay for £30 and toyosports for £86? They are both the same size but will they both flow the same or differently? Anyone used a universal one from bay or got the toyosport one?
  10. #729
    Apr 2012
    Some pictures of my AH Fabs V2 FMIC, all went well, thanks for all support in this thread !
    Pedrosousa likes this.
  11. #730
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,785
    Nice one. How was it getting the bumper back on? Tight as a nuns chuff isn't it?
    Did you use the small section of OE hose from the passenger side (from 90 degree alloy to map hose)?
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  12. #731
    Apr 2012
    Quote Originally Posted by Sam_ View Post
    It was tight indeed ! I had to made some insertions in the bottom front of the bumper and I removed the black cover, then it was easy
    And yes, I re-used an OE hose at right top if you are in front of the car ;-)
  13. #732
    Oct 2012
    140
    Gents. im planning on staying with my k03 on my AGU.
    I do not want to introduce lag in to mix. Considering this, would 2.5" on the hot side pipework be too large? Paradox yours looks huge!
    I will be using a core half the size if the welly, but still using 2.5" inlet/outlets with 2.5" to match the TB.
  14. #733
    nanananananananan BATMAN
    May 2012
    JHB, South Africa
    1,081
    Add MIGGZ on Facebook
    AH Fab / Ebay / Forge S3 FMIC (image heavy)
    Quote Originally Posted by paultownsend View Post
    I always use 50mm from turbo to inlet of fmic then 63mm from outlet of fmic to tb.
    My rides thread : http://www.audi-sport.net/vb/a3-s3-f...t-journey.html
    Quote Originally Posted by Paradox1 View Post
    Healthy??? no,no,noooo
    Mine is healthy
    yours is on steriods!!!
  15. #734
    Sep 2012
    69
    im sorry if there is already a post for it but iv read all as much as can take trying to find it but can someone put an ebay link to the "welly" cooler please or is the AH cooler the "welly" cooler im so confused wright now lol cheers
  16. #735
    Sep 2011
    so is the ah fab v2 cooler the one known as the welly cooler? As I was told to get the wellycooler from my tuner. If this is the case brilliant if not I think I like the look of the AH fab V2.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,470
    I run a wellycooler . I've run over 30psi thought with without any problems on my 530+ bhp engine and i plan to up the boost after a few mods
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  18. #737
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    No the Wellycooler is different mate..... Basically the Wellycooler is cheap as chips and the AH Fabs isnt..... Both as good as each other.... Keep fogs with Ah fabs.... Lose fogs with Wellycooler although people have managed to keep them....
  19. #738
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    882
    Add Vex182 on Facebook
    After now figuring I need to look at a fmic due to massive inlet temps yesterday on a local RR day. I am thinking something along the lines of this. http://item.mobileweb.ebay.co.uk/vie...id=20720800726
    Looks a good size for a k04, just a bit smaller than a Wellycooler which is what I am after. Looking at it I just need a couple of 90 degree pipes, some silicon piping.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  20. #739
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Quote Originally Posted by Vex182 View Post
    I assume you're after a smaller core to try and keep your fogs? The welly cooler has been tried and tested plus it can be made to fit without loosing fogs. Why don't you get one as you know it'll do the job easily, that other core might still be a massive PITA to fit.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  21. #740
    Vex182's Avatar
    Apr 2012
    Hinckley
    882
    Quote Originally Posted by Westy View Post
    I do want to keep fogs but also I just think it looks to big!
  22. #741
    Westy's Avatar
    Dec 2008
    17,280
    You can only see a little bit of it once it's behind the bumper! Anyway it does a bloody good job for the price. I'm only recommending it so much because I tried running a smaller FMIC alongside one of the stock SMIC and it still wasn't up to the job. I don't want you to go through the same grief I did.
    jitvv likes this.
    S3 Build Thread
  23. #742
    Vex182's Avatar
    Apr 2012
    Hinckley
    882
    I know, cheers. I just want it hidden as much as possible so by looking though at what others have done and coolers that have been to small, this seems to be the best all rounder of size inc. fitments on the sides. I would remove both smic's too.
  24. #743
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    There is always the B5 'Gringo' cooler...
    https://www.facebook.com/photo.php?fbid=315384535246305
    <tuffty/>
  25. #744
    A3AH's Avatar
    Dec 2011
    365
    are all the required parts for the wellycooler in here because I cant find them and I want to order my FMIC :/
  26. #745
    Oct 2012
    140
    @Paradox. Did you manage to fit the golf bumper back on ok? Any pics?
  27. #746
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    not very well paul lol
    The golf bumper curves from the bottom. I'll try and get some photo's when my cars back from the body shop. you do need to cut the sh1t out of the bumper though. its mostly the pipes that stop the bumper going back on. I've got a r32 bumper that i will throw on if I cant get the standard one sitting right
  28. #747
    limbo118118's Avatar
    LORD
    Oct 2009
    Wrexham.. North Wales
    355
    Add limbo118118 on Facebook
    anyone got a shopping list for the 'wellycooler' piping an hoses an clamps needed?? or is it the same as on page 1???
  29. #748
    russwuss's Avatar
    Feb 2013
    458
    First off, thanks to everyone that put this thread together - took me two hours but I can honestly say I've read every bit of information within the thread - without some of the key players on this forum the S3 tuning scene wouldn't be what it is today, makes the experience of owning an S3 much better with experts / advice to hand - really do appreciate it and couldn't thank you all enough.
    Once funds allow, it's gotta be the AH Fabs IC - I noticed there's a deal on at the moment in the classifieds for the V1 version @ £250.. Stage 1 standard K04 at the moment so that should be fine, but should this turbo ever die I'd be looking towards beach buggy hybrid (been following you're work on Facebook if you're reading ) so think I'm gunna bite the bullet and go V2 now...
    AH Fabs, if you're reading this... Will you be doing the same lower price deal for forum members on the V2? Wallet is going to be £1000 lighter tomorrow once I pick the car up from the garage so it won't be this months pay haha.. Just wondered if there was anything in the pipe line?
  30. #749
    russwuss's Avatar
    Feb 2013
    458
    I do have one question for everyone that springs to mind, I'm sure it's not on the thread - but isn't strictly related.
    FMICs are fitted to lower IAT's which I'm guessing is Intake Air Temp? (I did search for IAT in Google and ASN and honestly couldn't find an answer haha) IIRC temps is block 004 on VDCS.
    What would you guys class as an acceptable/good value? I've noticed some people have experienced temps below 3degC in winter, another was 11deg outside, IAT going from 18 - 30 degC - this is with an FMIC fitted.
    Wouldn't mind doing a few logs when I get my car back, just to do a sort of before and after study to show improvements.
  31. #750
    ollie2013uk's Avatar
    Mar 2013
    61
    OH MY GOD!! Finally got round to fitting the intercooler, I went for the recommended AH FAB one. My rating of it is good, nice size, light weight, and bolts exactly where it should. Obviously I had to make a few adjustments, cutting the crash bar and moving the horns to the passenger side SMIC bracket. I bought all the pipes and tubes as instructed on the 1st page. Everything was of exceptional quality.
    Everything fits perfectly however the front bumper was an absolute pig to get back on, the T clamps were the wrong way round resulting in the bottom of the bumper not fitting.
    The fog lights were an absolute pig to retain, I manage to keep the drivers side but I have lost the passenger side, after several hours of arguing with the bumper it finally clicked into place!!
    I can safely say that it was quite satisfying to complete this on my own as I normally take my car to the garage.
    Pics below:
    With Bumper finally fitted:
  32. #751
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Sorry dude but you have done something wrong somewhere... the V1 and V2 are designed to retain foglamps (I know I designed them to do this) and fitted mine to retain them... I suspect the hoses need trimming is ll... there was a little trimming to do on the bracket but thats about it...
    <tuffty/>
  33. #752
    Mar 2013
    61
    <tuffty/>
    I've no doubt I did something wrong somewhere, to be honest, i'm going to replace some of the hoses to hide them better. I don't use the fog lights anyway so i'll do it over the next few weeks. I was also just wanting to get my bumper back on and have a beer!!
  34. #753
    Oct 2012
    140
    chaps, just compiling my shopping list.
    Do we think a medium sized cooler with 2.252 coldside/2" hotside will be enough for a k03 pushing a mere 16psi peak?
    I may move to a k03s sometime in the future, but its not confirmed.
  35. #754
    russwuss's Avatar
    Feb 2013
    458
    AUDI S3 - FRONT MOUNTED TURBO INTERCOOLER FULL KIT 20v Turbo 1.8 | eBay
    has anyone brought this before? only just spotted it on eBay... looks like an alternative to the AH Fabs!
  36. #755
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,785
    The v1 yeah, smaller than a v2 though.
  37. #756
    Apr 2013
    12
    Just to clarify the thread and put like install kit. The kit will this?
    2 x
    Black Silicone Hose Elbow 90 Degree 63mm | eBay
    2x
    63mm Diameter Alloy Bend Elbow 90° Degree Aluminium | eBay
    And Steel clips what size?
    Did i miss something? I saw the conection between the FMIC and the aluminium conection elbow its a piece of silicone. What is that?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Quote Originally Posted by chemicalboy View Post
    2 x
    2x
    In context of which FMIC? there are several types dotted about this thread...
    Clip size range is typically silicon hose ID + 6mm so on 63mm hoses thats 69mm... JCS do a 70 and an 80... normally use 80's on 63mm hoses...
    <tuffty/>
  39. #758
    Apr 2013
    12
    Sorry tuffy, i said about the AH v2.
  40. #759
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    In which case yeah... that list is ok... use JCS Hi-Grip stainless steel clips...
    <tuffty/>
  41. #760
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Hi guys, I'm looking at getting fmic in the next couple of weeks, where is the best place to buy 2.5" piping from? I have an A3 agu.
    thanks simon
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
Tags for this Thread
