EM TuningAH Fabrications
Page 18 of 21 FirstFirst ... 81112131415161718192021 LastLast
Results 681 to 720 of 818
Like Tree23Likes
Thread: AH Fab / Ebay / Forge S3/A3 FMIC installs (image heavy)
  1. #681
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    thanks everyone i went back and got the cooler in the end and matched up some bolts, i did get some funny looks though.
    right be gentle please as im still trying to get my head around 'vvrrrooommmttssshhhh' (turbo) engines
    am i right in saying the two red boxes are where the cooler needs to get to??
    if so will my pipes replace these? im using the pipes 'Westy' used, and it does'nt seem like i have enough pipes....
    Silver S3 02 AMK
    !!!!STANDARD S3 EXHAUST FOR SALE!!!!
    PM FOR DETAILS
    click here for
    IN AND AROUND THE M25 RING MEETS
  3. #682
    Dec 2011
    Hockley Essex
    309
    Yes mate spot on
  4. #683
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    AH Fab / Ebay / Forge S3 FMIC (image heavy)
    Your pipes won't replace the top two in the box's or a plastic one that runs down the front of the battery but all will become very clear once you go to do it and have the bumper off
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  5. #684
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    also whats this?
    sorry for all these stupid questions
    Silver S3 02 AMK
    PM FOR DETAILS
    click here for
  6. #685
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    No probs mate
    That's the nozzle for WMi (water methanol injection)
  7. #686
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    thank you im just making sure i have it all right in my head before i get half way through and have no car
    Silver S3 02 AMK
    PM FOR DETAILS
    click here for
  8. #687
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I doubt you have water meth so I wouldnt worry about it.
    You may need a map sensor flange from forge if you havent already got one.I needed one for my golf but im not sure on the s3 setup
  9. #688
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Na won't need one on the s3 unless changing the route the pipes take like me and a few others have done but for yours and how most have done the "wellycooler" you'll utilise the oem map sensor tube in front of the battery
  10. #689
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    i notice the OEM MAP sensor tube has an 'dent' in it surely this is very restrictive?
    Silver S3 02 AMK
    PM FOR DETAILS
    click here for
  11. #690
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Can't imagine it helps but theres no documented proven gains that I know of, although common sense would say that a normal pipe is better than the oem shaped one
    Iirc welly is still running the oem map tube and pushing out well over 400bhp
  12. #691
    Dec 2011
    Hockley Essex
    309
    UNIVERSAL INTERCOOLER TYPE H 550x225x64 PIPING KIT 2.25 | eBay
    Has anyone fitted this kit as it smaller then the welly cooler and may fit better?
  13. #692
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Quote Originally Posted by S3 JOHN View Post
    Smaller pipework than the S3... avoid personally...
    <tuffty/>
  14. #693
    Dec 2011
    Hockley Essex
    309
    <tuffty/>
    But the forge and ah fab coolers have 51mm tubing and this has 57mm
  15. #694
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    ...the AH v1 has 51mm... v2 is 63mm... while you have a point you asked if this was a suitable alternative to a welly cooler... in context it isn't IMO... compared to the Forge and AH v1 then arguably it is but... seeing as the original reason for 51mm was to aid easy fitment in an OEM style and now there are solutions to use bigger I can't really see why anyone would go smaller now..
    The cooler in the link 'should' be ok but you need context... it should be ok for stage 1 and stage 2 but not for stage 2+, hybrids or BT imo...
    Try it... but tbh I am past the compromise stage of flow these days... having seen how much small pipework can hurt power and seeing as there are suitable solutions for FMICs on S3's these days I am struggling to suggest going smaller than 60mm... 51mm was in the days there was nothing else out there
    If you could get 60/63mm bends welded on its no less deep than the AH v2 but doesn't look like it has the rows or surface area..
    <tuffty/>
  16. #695
    beachbuggy's Avatar
    Surrey
    1,741
    Just read through 18 pages and can't find the answer,
    What pipe work are people using on AGU's or left handed manifolds to feed the dv and n75. Can't see any reference to those that have done this on an AGU as to the pipe work for the dv or where they've run it froM, on Prawns it looks it a forge cold side dc relocation kit. I'll probably weld on some pipes but just interested as to others
  17. #696
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    my N75 take off is a 1/8th NPT 6mm brass hose tail Dan, screwed into the pipework and sealed with chemical metal.
    I used to run a cold side relocation on the DV, but Niki didn't like it and had the DV take off welded onto the hot side pipework near the turbo outlet
  18. #697
    beachbuggy's Avatar
    Surrey
    1,741
    DV welded to hotside... Perfect.... thanks Nick
  19. #698
    ants 8L's Avatar
    boost is what u need
    Jul 2012
    Halesworth Suffolk
    13
    AUDI S3 - FRONT MOUNTED TURBO INTERCOOLER KIT 20v Turbo 1.8 | eBay
    can any 1 tell me if these kits are rateable
    ITS COSTING A FORTUNE !!!
  20. #699
    Jpd89's Avatar
    Jun 2012
    West Sussex
    104
    50mm outlets are a bit too small, just go with the 'wellycooler' option, for less £ and better intercooler
  21. #700
    Sep 2005
    Derbyshire
    180
    This updated V2 AH Fabs FMIC is available now... give AH a call and ask for Lars...( AH Fabrications - Contact Us) pricing is around the £350 mark plus you pipes to join it all together which are now simpler (2 x 63mm 90 deg alloy bends and 2 x 63mm silicon 90 deg elbows plus clips)<tuffty/>
    I just want to ask, as the above post isn't quite clear (to me anyway). If I order the V2 from AH Fab, I get everything to fit it onto the car for around £350, so pipes, joiners, clamps and fitting braces etc, is this correct?
    I only ask as there's quite a lot of reading in this here topic.
  22. #701
    Feb 2012
    bedfordshire
    737
    Quote Originally Posted by Blackcupraa View Post
    You only get the intercooler mate but you can get all the bits you need from eBay for £60, I have all the pipe work and clamps and that's how much it cost me just need to get my cooler but that will be later on
  23. #702
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    No... the v2 FMIC is around £350 (typically +vat) from what I understand... the pipes are extra and will cost around £100/£130 (depending on what you buy and where you get it from) more on top... not sure what you mean by fitting braces but the V2 comes with brackets... you also need to cut the bumper bar for clearance...
    Overall works out cheaper than a Forge FMIC while supporting more horsepower than the Forge..
    <tuffty/>
  24. #703
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    669
    If you order from AH Fabs, make sure you speak to Lars and request the V2. Otherwise you will get the V1.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
  25. #704
    Sep 2005
    Derbyshire
    180
    All good words, thanks guys!
  26. #705
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by Dan-Jnr View Post
    And make sure he knows the engine is in the front.....
  27. #706
    RIP S3dave
    May 2004
    nr Glos
    7,131
    make sure AH fit the damned brackets on the right way round!!!!!
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  28. #707
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    I think my FMIC may of arrived this morning
    Am going down a slightly different route as i have gone far a slightly smaller cooler with a delta fin design still using 63mm outlets and pipework as shown in posts above.
    Future is gonna give me a hand fitting as he has already mocked up his FMIC install so hopefully will get a few pics when we do it.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
  29. #708
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    this is the cooler i have opted for High Performance Racing Sport 2.5" 450x230x65mm Front Mount Intercooler deltafin | eBay the one i am getting is an Apexi one as its basically the same but they were out of stock of the gReddy`s
    I am not gonna go BT on this car so stage 2 is probably it for me so that cooler should be ample for my needs and a reasonable upgrade to the SMIC`s.
    Got the pipework as per the design in this thread to keep the foglights from mrsilicone off ebay and so far am looking at a sub £200 FMIC install
  30. #709
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Quote Originally Posted by vrbob View Post
    I hope you have more success with a smaller core then me. Mine was a fair bit smaller but run along side one of the original side mounts and it just wasn't up to the job of stage 1 let alone stage 2 but I wanted to see if my idea would work. It's good to see people willing to try different things, so hats off to you Bob.
    You can read about my FMIC fitting here:
    W3STY's Progress Thread
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  31. #710
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Cheers Westy,
    yeah willing to have ago and see what happens as hopefully the deltafin design of this cooler will aid it and allow me to run smaller dimensions and still provide adequate IAT`s.
    I had a brief run through this thread yesterday looking a t the evolution of the FMIC`s since Tuffty`s first stab at it with the tiny little cooler and small outlets. So i think i have found a viable package for my needs and also budget lol.
    Obvioulsy only time will tell (and of course some logging)
    Will check out your thread now bud cheers
    *Edit* Out of interest what size was that cooler you ran with one SMIC?
  32. #711
    Westy's Avatar
    Dec 2008
    17,264
    I was trying to find the dimensions for you but couldn't. It'll be in my thread somewhere but it's a bit of a maze in there All I can find is the in/out were 57mm.
    S3 Build Thread
  33. #712
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Yeah 71 pages lol!
    from your pics it looks a bit like this one FMIC FFRONT MOUNT TURBO INTERCOOLER 2.25" TYPE S 550x140x65MM | eBay
    So the one i went for looks alot taller but slightly shorter but also thicker so i think all should be good as i wont be going past 300bhp
  34. #713
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    whilst lookking at your build thread i found you had posted a link to your FMIC and its still for sale on Ebay Universal FRONT MOUNT INTERCOOLER 560 x 180 x 63mm | eBay
    so 560 x 180 x 63 and the one i am going for is 450 x 230 x 65
  35. #714
    Westy's Avatar
    Dec 2008
    17,264
    So yours is not as wide but it's taller and 2mm thicker? Might still be too small mate but you wont know without trying.
    S3 Build Thread
  36. #715
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Yup fingers crossed its gonna be ok i think it will but am not very clever with this sort of stuff.
  37. #716
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    quick pic of my cooler that arrived
  38. #717
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    still a good size for your needs as you say.
    good luck
  39. #718
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Cheers Karl yeah for what i want i think it should be all good plus easier to fit as its on the smaller side and keeping my fogs OEM looking.
    Hopefully the delta fin design aids the design a bit allowing better coolinmg on a smaller core.
  40. #719
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Fitted my FMIC yesterday so have made a quick thread with some pics here
    FMIC fitted :)
  41. #720
    ants 8L's Avatar
    Jul 2012
    Halesworth Suffolk
    13
Tags for this Thread
