AH FabricationsBadger5
Page 10 of 21 FirstFirst ... 3456789101112131415161720 ... LastLast
Results 361 to 400 of 821
Like Tree23Likes
Thread: AH Fab / Ebay / Forge S3/A3 FMIC installs (image heavy)
  1. #361
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Quote Originally Posted by Spankys3 View Post
    Well I think one of these should be on the cards now then. Cheers for doing the write up. With length do you recommed for the alloy 90oc bends?
    I used std Forge alloy bends... they come in one length as far as I know... not sure if for the other S3 we cut them a bit and redid the bead or just left them std length... my fabricated ones were cut and bead rolled afterwards...
    <tuffty/>
  3. #362
    Spankys3's Avatar
    May 2010
    West Sussex
    40
    Cool cheers for info. Was looking on ebay and you can get different lengths on the bends. But i will get the forge ones. They are not beaded tho. They dont look it in the pics.
  4. #363
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    I think it does depend.. have seen some from Forge that aren't but all the ones I have seen recently have been...
    <tuffty/>
  5. #364
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    695
    Great update Tuffy. Love the time and effort that's gone in to this to provide a decent product with proven results.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
  6. #365
    Jun 2011
    S.E. Melbourne/ Australia
    146
    Nice write up Tuffty.
    Do you happen to know what size is the core alone without the end tanks and what style core (looks to me tube and fin) is?
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
  7. #366
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Don't remember the dimensions no but it should be noted that is not always the size that makes a difference... the row spacing on this core is tighter giving more rows for the same height...
    The v1 core was 13 rows compared to the v2 which is 22 (might be 21 as I can't remember if I lopped off 3 or 4 rows to get it to fit...)
    Its the same depth at 62mm and you can see the width difference in the pic below..
    The core is made up thus...
    <tuffty/>
  8. #367
    Jun 2011
    146
    Thanks tuffty for the info.
    That is a tube and fin matrix.
    I'm only asking as the depth of my core is 55mm and the end tanks are 63, 450 wide and 230 tall.
    With this setup i see temp dropping on boot up to 4500 rpm, after that temp raises an average of 20C above ambient temp at 6000 rpm.
    I might need a deeper and wither core and stick a wmi kit.
    dusty likes this.
  9. #368
    Chugger
    North Devon
    2,716
    I could use a bit of advice on pipework require for the Welly style toyo setup as I cannot find much detail at all. So far all I know for sure is
    2x 76-63 bent 90 reducers
    1x 63mm 90 (for charge pipe)
    1x 63mm coupler onto tb
    2x 63mm alloy 45s
    2x 63mm alloys 90s
    Please feel free to correct me as id like as little wastage as possible. I don't mind getting parts welded up. I did look into just buying the toyosport 63mm universal pipe kit, but put off by the lack of bead on the pipes, and in unsure that my local engineers will be able to flare the ends. Anybody running pipework without the beaded pipe with no hassle?
    57 A3 2.0 TDI Sportback (140)
  10. #369
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,284
    Quote Originally Posted by sportstractor View Post
    2x 63mm alloy 45s
    2x 63mm alloys 90s
    I'm guessing by the list above you are going to use silicone reducers that come out of the fog grills like mine? If you're not too fussed about getting bits welded up you could speak to Bill as he has fitted one of these cores upside down and made welded pipes so that the fog lights could be kept.
    I strongly recommend that you get beaded pipework. Tam tried none beaded and it was constantly popping hoses. Removing the front bumper on the hard shoulder of the M25 in the dark to put a hose back on is not fun
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  11. #370
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    2x 63mm alloy 45s
    2x 63mm alloys 90s
    This may be of some use to you...
    Intercooler bits and bobs arrived :)
    <tuffty/>
  12. #371
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    907
    Hey guys sorry to be a pain etc but after reading through much of this thread and with there being so many different options I am after some advice on which FMIC to go for on my s3 or which way to go about it. Ideally I'd quite like to keep the fogs, but also want it to be as easy as possible and relatively cheap if pos.. Unsure where to start really, also I have no technical knowhow whatsoever so won't be attempting this myself. whether to go for a kit or get bits seperately, I'm thinking seperately will be cheaper? and also beaded pipes i'm not really sure what they do what advantage they have except reading without them there is more risk of popping clips off or joiners off or something... Any ideas/help ?! Cheers, Josh
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
  13. #372
    Chugger
    North Devon
    2,716
    <tuffty/>
    Thanks tuffty, exactly what iv been looking for.
    Quote Originally Posted by Westy View Post
    yeah using the silicone bends out the intercooler seems the best idea looks wise. Im not bother about losing fogs so il do it the same way as yours, im already missing a lower grill so saves me buying one :P Roger roger, beads are a must, good to know.
  14. #373
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Quote Originally Posted by JtotheD View Post
    AH Fabs V2 (update in forst post of this thread) is the easiest option to fit/keep foglights and is around the 350 quid mark plus pipes/hoses...
    You MUST use beaded solid pipes else your hoses WHILE pop off under boost... no ifs or buts...
    <tuffty/>
  15. #374
    Westy's Avatar
    Dec 2008
    17,284
    If I ever get round to it I think I'll ask Bill nicely to weld custom pipes to mine so it can be set upside down then I can get a new bumper with fogs again.
    S3 Build Thread
  16. #375
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    As its relevant to this thread and discussions to do with Toyosport or eBay FMIC's...
    FMIC with modded end tanks...
    Fitted to car (stealthed of course with satin black paint) and the drivers side pipe work...
    ...passenger side pipe awaiting WMI nozzle boss to be welded then painted black too..
    ...pic showing the route of the endtanks...
    ...I know what your are thinking... how well does that fit behind the bumper.... answer is that the pipes do catch however I modded the lower surround and fog grilles...
    ...and the bumper fits as well as any Forge/AH FMIC I have fitted in the past...
    <tuffty/>
  17. #376
    JtotheD's Avatar
    Events Moderator
    May 2011
    907
    <tuffty/>
    thanks, right beaded pipes it is. saying that though, I still don't know what exactly they are, or is it a case of getting the hoses/pipes listed in the first post in the v2 ah fab one and making sure they're all beaded? sorry again for showing my lack of technical skill! Josh
    check it out!
  18. #377
    Westy's Avatar
    Dec 2008
    17,284
    Beaded means the ends are flared so that the clamps grip better.
    S3 Build Thread
  19. #378
    Chugger
    North Devon
    2,716
    Westy, I don't suppose you could be a legend and post a list of the pipework you used? Wellys seems to have done the whole job in 76mm which is overkill for stage 2 power which I'm looking at surely, and I don't quite understand why he has 2x 63mm alloy couplers there.
  20. #379
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    As in why I used the 63mm couplers? I did use some and I think it was to join up to the OEM boost hoses. I used a 76 - 63 reducer hose and then coupled onto the OEM boost hoses.
    Homer Simpson
  21. #380
    Westy's Avatar
    Dec 2008
    17,284
    Ok mate. I'm also taking the front bumper off again tonight to look at my WMI so I can take pics for this thread at the same time.
    Mine uses 76 > 63 silicone reducers straight out the end tanks so that I then use 63mm pipework into the charge pipe and map sensor. Welly stayed with 76mm hose for as long as he could then he reduced down to the 63mm to fit the charge pipe and map sensor. He would have used one of the 63mm couplers to join the reducer to the boost hose from the charge pipe. Not sure about the other though.
    S3 Build Thread
  22. #381
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I used the second one for the intercooler inbound size. Went from 63mm OEM hose from charge pipe up to 76mm.
    Homer Simpson
  23. #382
    Chugger
    North Devon
    2,716
    Ah that makes sense, I was thinking you had gone right up to alloy charge pipe and tb. I really need to get the bumper off and cooler in place to assess what iv actually got to do... Although connection onto original hoses makes far more sense
  24. #383
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Made the job so so easy to do.
    The 76mm helps with passage through the cooler. Lets put it this way, going from 63mm up to 76mm, through the cooler, and then back to 63mm hasn't held me back in any way.
    And it makes fitment easy peasy. With the added benefit of some 76mm piping.
    Homer Simpson
  25. #384
    Westy's Avatar
    Dec 2008
    17,284
    As promised, here are a few bad pics
    First up is the passenger side:
    - 1 76mm to 63mm silicone 90 degree reducer going into a 90 degree 63mm alloy bend, going into a 90 degree silicone 63mm bend up to the map sensor.
    Drivers side is like this:
    - 76mm to 63mm silicone 90 degree reducer into a 63mm alloy coupler, into a 63mm 90 degree silicone bend, into a 90 degree 63mm alloy bend into the silicone hose on the charge pipe:
    So if you do it my way you will need the following:
    - 2 76mm to 63mm 90 degree silicone reducers
    - 2 alloy 63mm 90 degree bends
    - 2 63mm 90 degree silicone bends
    - 1 63mm alloy coupler
    Obviously a lot of it needs trimming but hopefully this will help.
    S3 Build Thread
  26. #385
    Chugger
    North Devon
    2,716
    wicked, cheers westyward.
    the black pipes actually look better than the fogs
  27. #386
    Westy's Avatar
    Dec 2008
    17,284
    No problem matey. If you need any more help, pics, advice, just let me know.
    The pipes definitely make the front end look a lot more aggressive.
    S3 Build Thread
  28. #387
    Chugger
    North Devon
    2,716
    cheers, im all ordered up now, plus a new extra hoses iv been meaning to sort. Hopefully i will have done the whole job for £185. Got the cooler for a little over £80, which may i say, seems like a flippin' barry-argain... eBay - The UK's Online Marketplace
  29. #388
    Chugger
    North Devon
    2,716
    just a quicky for those who have sprayed there cooler, iv bought some vht satin black paint, how did people prep there cooler? just a clean and spray straight on, or did you use etching primer? obviously want a durable finish, but dont want so much paint that it interferres with heat transfer
  30. #389
    Westy's Avatar
    Dec 2008
    17,284
    I couldn't be arsed to spray mine as the huge black hoses hanging through the fog grills kind of give the game away. If I'd managed to keep the fogs and went for a stealth install I would have sprayed it. Be nice to see what yours looks like with a black core
    S3 Build Thread
  31. #390
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    I used brake cleaner to degrease and a scotchbrite pad to key up the surface... only needs a light coat of decent paint... I use Rustoleum Hard Hat Satin Black... covers well and doesn't go washy like smoothrite tends too...
    <tuffty/>
  32. #391
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Where abouts do you get all the pipe work from? eBay? Is there a favourite seller to get it all from? I get my annual bonus this month and looking to do FMIC. And with a budget of about 200.
    Do you have to chop bits off the crash bar using that cooler in the link? That's the only thing putting me off...id rather not have to do that.
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
  33. #392
    Westy's Avatar
    Dec 2008
    17,284
    Quote Originally Posted by S3featesV9 View Post
    This is my seller of choice for all pipework:
    eBay My World - mrsiliconelso you shouldn't worry too much about cutting the crash bar. It's mainly there to shrug off very minor parking bumps and wouldn't hold up too well in a proper impact anyway. Once you have a huge intercooler bolted to the front of the car it'll replace any strength you lost from slightly cutting the crash bar.
    S3 Build Thread
  34. #393
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    all i did was cleaned it off using clutch and brake cleaner and spray straight onto. 2 coats was enough. no probs
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
  35. #394
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Anyone know the size of the n75 hose on these eBay intercoolers? I brought one from an agu but I need to fit it to a aum.I've already got the map sensor flange but nees to know the aize of the n75 pipr to get it welded.
  36. #395
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    I believe the N75 line is 6mm matey (anyone confirm?), sorry I've not replied to your PM's, I'm having severe laptop issues, it's just taken me 15 minutes to load this page!
  37. #396
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Not sure where your on about mate the N75 doesn't go anywhere near the cooler it has a feed from the charge pipe next to the dv feed, a pipe to the turbo actuator and another pope to the tip
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  38. #397
    Westy's Avatar
    Dec 2008
    17,284
    Quote Originally Posted by StaceyS3 View Post
    I think he has an A3 mate and the pipe work is different to our S3s.
    S3 Build Thread
  39. #398
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Westy fancy making me a set of brackets like what your using for some beer tokens .
  40. #399
    Westy's Avatar
    Dec 2008
    17,284
    Not really mate but I can give you the measurements I don't have any metal left to do these.
    S3 Build Thread
  41. #400
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Quote Originally Posted by StaceyS3:1460962
    sorry should have mentioned its for a mk4/a3 setup
Tags for this Thread
