Monster MotorsportVolks Autos
Results 1 to 7 of 7
Thread: Wheel spacers
    Jun 2009
    77
    Wheel spacers
    A good pal of mine has kindly donated his old 18'' RSTT replica rims off his golf mk4, do these require spacers the fill the arches on an S3?? If so, do people use bolt on spacers or just the normal ones with longer bolts.
    Edit: These rims are replica ones, do the genuine centre caps fit? The copys are shockingly ****e !! TIA
    1999 S3 Quattro. Stolen by my cousin in exchange for pennies !!
    Honda Civic Type R Premier
    Sep 2006
    63
    If they are et35 I would recommend 20mm rear and 10mm front.
    If you go for H&R you can use the DRA's for the rear that bolt on and the DR's with extended bolts for the front.
    Heres mine with 20mm on the rear with et35 wheels -
    Jun 2009
    77
    Needs lowering now !! Looks good mate.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    The angle of the photo makes it look like you have it on stilts
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    As said, 20mm and above are bolt on and anything less are bolt through.
    https://www.dpmperformance.co.uk/s3-...1998_2086.html
    Damian @ DPM
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    I'm running et35 OEM RSTT's on my S3 and they look miles better with spacers. I went 15mm at the back and 10mm at the front (H&R ones with longer bolts). The before and after pics are below.
    Before:
    After:
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Jun 2009
    77
    Can i borrow your centre caps and not give them back?? Looks very nice from what i can see !
