Monster MotorsportEM Tuning
Results 1 to 8 of 8
Thread: VAG COM codes
    May 2009
    62
    VAG COM codes
    Control Module Part Number: 06A 906 019 AM
    Component and/or Version: 1.6l 2V/R4 SIMOS HS2585
    Software Coding: 04000
    Work Shop Code: WSC 06313
    2 Faults Found:
    00668 - Supply Voltage Terminal 30
    36-10 - Open Circuit - Intermittent
    Control Module Part Number: 1J0 907 379 G
    Component and/or Version: ABS 20 IE CAN 0001
    Software Coding: 03504
    Work Shop Code: WSC 06435
    1 Fault Found:
    16-10 - Signal Outside Specifications - Intermitten
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    May 2009
    62
    cheers but where the control module
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    From what I understand they are built into the parts they control, one of the codes has ABS prefixing, the other 1.6l so I assume you have a 1.6ltr A3? I would check the earths under the battery tray as a starter... Need to remove the battery and the battery tray IIRC...
    <tuffty/>
    May 2009
    62
    cheers mate wil do
    May 2009
    62
    do you think rhat would stop the engine turning
    26,716
    Well given its mentioning terminal 30 electrical circuit errors then yes that could very well take out a number of important systems, check the wiring as already advised cause open circuit is 99% time a wiring issue, loose or broken wire.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Given the starting issue, I would get the battery checked out too.
    <tuffty/>
