Sky InsuranceVolks Autos
Results 1 to 35 of 35
    S3 Paul's Avatar
    Oct 2006
    2,764
    Intercoolers ( Not for banter please )
    Right,
    In "the other FMIC thread" a few questions were raised that did not realy get answered.
    Is the forge item the optimum size core?
    I was under the impresion that the boost pipe work should be the same as the standard pipe work 61mm or there abouts? if any reduction in size it should only be on the "hot" side of the cooler as air like oil moves easier when hot than when cold?
    I understand also that a "good cooler " will need to lower intake temps while giving very little preasure drop ( if any ) ?
    Are tapered end tanks ( inlet and outlet in the middle of the end tanks) much better for the s3 than a "normal" design with them at the bottom. ( i asume the air will take the path of least restriction)
    Noggy Blue 2001 S3
    MAD_Adamski's Avatar
    Jan 2009
    314
    i will try and answer this without causing issue's... right is basically down to what you want? the std items are quite good from what i gather from what i have read on here. NOW some would say that the forge and the AH fabs coolers are OTT for the average user and a ebay jobby will do.... the pipe sizes will no make MAJOR differences and again depends on what your after? do you wanna keep the grill and gogs etc? if so then smaller pipes if your after raw use then do away with them and fit the bigger pipes. as for pressuredrop etc its not just down to the pipes its down to design and flow and the core too its really not a question any of us could really answer without physical eveidence...
    IF i was to advise you on my experiences and what alex has taught me over the few yrs its tailor it to YOUR needs! you dnt need buy a big huge one cause its fancy and does 1000hp and again dnt buy a cheap as chips one off ebay cause it'll do the job ok.
    Buy the cooler that you think best suits you if you funds are tight and you dont wanna spend much then maybe go for the cheapest option? If you dnt mind doing stuff yourself and wanna save money for a good cooler seup like tufty, maybe the AH fabs? or if you want one thats expensive yet been fitted a few times and comes all in 1 kit then perhaps the forge is for you?
    The basis really is there all good in there own mind it just really depends on what you want?
    on my cossie i knew i'd wanna go for 400-500hp so i got the upto 700hp cooler so i never have to worry yes it was trid and tested but its fit and forget and not regret later wen its not doing its job. and i have been on both ends of the scale when i should have spent once and spent twice, but on other hand some times gone OTT then gone back lol....
    So you really have 3 options, ebay, AH, or forge i personally feel your wallet and what you want out of it is the decider here...
    Edit: to say the pipes are better at the top or bottom as long as the end tanks are designed correctly rather than centre.
    HTH Ad
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    I too would suggest a core from a reputable maker...
    But from there on, I'd not worry too much.
    It's a 1.8 engined Hatchback making 270BHP...how fantoosh does the FMIC have to be to drop 40-50 degrees of intake temperature.
    I've never seen any proof that there is ANY difference between 51 and 51mm pipework when it's fitted and working.
    Is the forge core ideally sized? I don't know.
    It's bigger than the one I had and it worked just fine.
    In my view, as long as the core is of reasonable quality (design, flow capacity, efficiency) it'll make no difference that anyone will be able to detect when fitted to an S3 making around 270 BHP.
    It's not a Championship winning race car where every fraction of a BHP/lb-ft is essential...it's a road car.
    Anything is better than nothing...as long as the components are of relative quality, I'm damn sure you, I or the next man will never be able to tell one apart from another.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    Well I received my Forge Intercooler the other day. Im going to fit it end of the month when I have time off. Will try and take pics and give a verdict but I dont have vagcom to take readings just now.
    2003 Audi S3 + Go faster bits
    Feb 2008
    2,817
    looks like a nice piece of kit!
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Nice!
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    I'm not sure what the standar done looks like. Is the Forge one miles bigger? Does it require losing front fogs etc?
    I've seen some that can be seen from the front and protrude out and think it looks terrible. Hope that one doesn't do that?
    Is there not a simple replacement that can fit in place of the existing and give decent results due to its better design?
    How much?
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    I have to say that there is a world of difference in the quality and performance with regards to the cooling efficiency of the Forge and A&H air cores , both these companies are using some of the best availible in the UK , ( we tested 3 types before sttling on the one in our kit ) The E bay cores simply do not offer the same cooling efficiency or performance ...hope this helps
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    Quote Originally Posted by S3 Rav View Post
    MMMmmmmmmmmmm
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
    S3 Paul's Avatar
    Oct 2006
    2,764
    Quote Originally Posted by Forge View Post
    Could you please tell me by how much the forge cooler was better at its job than cheaper universal intercoolers ?
    I have sold cheaper coolers to a good few of the local tuners around where i live.
    All of them have been happy with the results they have had.
    In real world terms would any of us notice the diffrence ?
    Ive suplied cars such as...
    evo 6 now running 600bhp atw
    integra type R turbo 320bhp
    honda civic turbo 400bhp
    Corsa B turbo 400bhp
    intergrale 400bhp
    Astra gsi 420bhp
    Now i know power figures mean nothing, but these cars do go on alot of track days and all have more gauges than a boeing 747 , All report a good Intake temperatures over a track day.
    Surely compared to the factory set up on our cars even a "cheap" intercooler fitted with well thought out pipe work would show a massive improvement ??
    Noggy Blue 2001 S3
    Jan 2009
    314
    Best from the horses mouth! i've always said the forge stuff is good i've even had some stuff on mine! but the cost is high but you are then supplying the kit. Which some people think is easy but its not for these companies as there day to day so constantly ordering small bits is a hassle... i can see why you at forge charge what you do and AH will never offer a kit as its too much hassle for them....
    IMO you can buy the forge or AH one both will give better than std or ebay results just depends if you can use a spanner or not and hw much your looking to spend .
    thanks for the input tho FORGE
    Jan 2009
    314
    Quote Originally Posted by S3 Paul View Post
    intergrale 400bhp
    Astra gsi 420bhp
    PAUL i'm no expert and sure alex or the forgee chap can give a more technical reason but i KNOW plenty of customers that have come in with these ''universal'' coolers saying here good but not quite right.
    As you listed i shall of a few i know
    1:- corsa turbo 30hp increase
    2:- fiesta rs turbo 20hp increase
    3:- (performace fords) escort turbo much cooler and 20hp increase!
    thats just 3 off the top of my head! And i know all this as i put them in contact with AH.
    On recieveing there new coolers from AH they then take the car to be retested on the rollers and everytime the cars have made 1. more power (upto 30hp in some cases) 2. been cooler...
    Now as said i'm no expert and this isn't my field but what i do know is facts and i'm sure the chap from forge gets the same thing, people asking to have these ''other'' coolers improved... now as said im sure there ok but its pure fact that beter cores WILL work better...
    fran-s3's Avatar
    1,090
    what does 'AH' stand for?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    AH Fabrications.... http://www.ahfabrications.com/
    <tuffty/>
    fran-s3's Avatar
    1,090
    Thanks Tufty, well if anyones thinking of doing a group buy on these AH Intercoolers I'm certainly in. Else I'll be purchasing one next month anyway....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    No probs... Not sure a group buy will happen as Alex has already suggested a price of 250 for the FMIC alone which TBH is a bloody good price...
    You will still have to mod your own crash bar and source the pipes but do it right and you will get a good cooler whilst saving some money.
    For those that are interested, google is your friend....
    http://www.gnttype.org/techarea/turbo/intercooler.html
    Think its all said there (not read through it properly yet)...
    I am still trying to find the time to get a proper write up of my FMIC installation. I might have some time tomorrow if my work VPN is still down...
    <tuffty/>
    Jun 2009
    Kent
    311
    Sorry to hijack (and to be honest I HAVEN'T done a search YET) - does anyone know of a good guide for fitting a FMIC to a TQS - I now know that it's not quite the same as an S3
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    Think it's about time we sorted a group buy from AH...
    Anyone?
    ...... Now this one's MUCH better!...
    fran-s3's Avatar
    1,090
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Yeah it is a good price I don't mind paying that at all... yours still running well mate?
    Great stuff cheers mate look forward to the guide.
    Jan 2009
    314
    I did try to arrange a grp buy while back to help everyone out with no benefit to myself i dont even own a S3! BUT to many people messed and caused hassle *james* *cough* and few were worried it would not be as good as the others for some reason....
    Alex has read all this, he read the last 7page one too, and was very tempted to post after some of the rubbish that people were puting, but in the end he said as usual the product will do the talking.
    As tufty has said alex wont mind doing a grp buy but as far as i'm aware the price wont change!? As that price is a V good price as it is trust me....
    Its a simple if you want one put your money where your mouth is and the phone number is listed below as tufty pointed out....
    you wont be dissapointed
    S3quatt's Avatar
    Jan 2007
    Sunny Scotland
    595
    Speaking of Tufty....
    Where's this write up??
    Looking forward to it like
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    soz guys, they fixed my vpn so had to work today
    I have a load of other viable excuses too but I will endeavour to get it sorted this weekend (family willing)
    <tuffty/>
    FazS3's Avatar
    Apr 2008
    857
    If there is a group buy I would be very interested in a FMIC for my r32.
    Give us a shout if you get anything sorted im not on here alot these days!
    MTM THE ULTIMATE STAGE!
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    I can vouch for the quality of the A&H stuff , it is excellant stuff , you wont go wrong .... IF you need an alternative to the same sizes or specs as the A&H I would be happy to help
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    Mines going to have to wait now due to been laid off
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    Rubbish mate
    <tuffty/>
  28. #27
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    Rubbish mate
    <tuffty/>
    Yup big time, just gald i ordered my upper boost hose and dv relocation kit beofre it happened, least i can fit them and my tip while im off haha
  29. #28
    Feb 2008
    2,817
    bad luck mate
  30. #29
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Adam, TBH there is no need to try and organise the group buy as the price Alex is knocking these out for is very good anyway, and he himself said there is very little movement on the price anyway. Anyone interseted can contact Alex on the details posted above.
    When Minty fits his forge, if he is willing to do a write up, i will stick his and Tufftys in the same post and stick it for all to see. Then when we get some one do a full Ebay fit i will stick that with them too
  31. #30
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    Gazzaone has got an ebay joby, ask im if hell do a write up to compare all three.
  32. #31
    Jun 2009
    Kent
    311
    Sorry to hear that mate
    Hope you get something else sorted quickly.
  33. #32
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    yeah i done it for him after he saw my post about me doing mine, ill add mine onto the sticky now then shall i
  34. #33
    Apr 2004
    12,520
    Go for it, i want one of each option in there. Will maybe lock it, or not depending
  35. #34
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,232
    Quote Originally Posted by s3_kev View Post
    Yeah, be a good way to gauge what people can afford and also to determine what route they want togo down.
  36. #35
    Jan 2009
    314
    thanks Forge not often these days companies are willing to speak kindly of others
