Sky InsuranceJMB Retrofits
Results 1 to 9 of 9
    May 2009
    29
    Heres a strange one!
    ok i've had problems with my air con, as in it doesnt work, and lately the bite on my clutch has been almost on the floor. well got in the car a min ago and could not for the life of me get it into gear, after alot of swearing i came to the conclusion that either the master cylinder has gone or the slave cylinder. then it goes in gear and the bite on the clutch is much higher, (about half way, and the air con is now working?!? the compresor is guite noisy doesnt really sound healthy. can anyone shed some light on this i'm scratching my head but you guys know alot more than me?
    May 2009
    29
    anyone?
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Well done, you waited a whole 4 mins for a response...
    Be patient and someone will be along to help.
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    there is no relation between your clutch and air con compressor I am afraid, its purely coincidental.
    They are seperate issues and should be looked at as such, I would start with the clutch.
    How many miles has the car done since the last clutch change?
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    May 2009
    29
    i dont know how many miles the clutch has done so i should really assume that it needs changing, ok so its pure coincidence but i'm still abit stumped as too why the clutch would get worse and worse and then suddenly yoink its fine again, never had that before usually it gets worse and worse then breaks! hmph either way its gonna be an expensive service
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Has the clutch pedal snapped?
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    If it had snapped he wouldnt really be able to use the clutch pedal at all, it'd just be sat on the floor
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    Quote Originally Posted by daveeeeee View Post
    .......but i'm still abit stumped as too why the clutch would get worse and worse and then suddenly yoink its fine again, never had that before usually it gets worse and worse then breaks.....
    Mine was like that though - not sure if the hydraulics were sometimes sorting themselves out when I parked-up?
    Mine turned out in the end to be the slave cylinder - I got a garage to bleed the system to begin with, which lasted about a week, then we had no choice to look further into it - hence the new cylinder
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
    May 2009
    29
    no the pedal hasnt snapped (yet) i'm betting its the slave cylinder, my luck is not good enough for it to be the master cylinder. as for the air compresor, im guessing thats knackerd its quite noisy at when the the aircons on full chat?
