AH FabricationsSky Insurance
Results 1 to 35 of 35
Like Tree4Likes
  • 3 Post By A3Tom
  • 1 Post By S3Steve
Thread: How To Fit a K03 TIP
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Thumbs up How To Fit a K03 TIP
    OK, so here we go...
    Well I was quite happily reading Michael Jackson jokes on the internet when I was disturbed by a knock on the door...."FANTASTIC" I think, Kelly Brooks come over but no, its a UPS man delivering my brand new shiney Forge TIP. Due to the chance of Kelly Brook coming to my house was slim at best I decided I'd better have a look at this TIP......its quite an elaborate bong I must say...
    Nice and smooth inside..
    All good. So I pop out and pick up a load of jubilee clips as I dont want to get half way through and be stuck...
    I wasnt going to take any chances so picked a load up...
    So its out into the garage to start things off..
    Firstly, engine cover off to reveal what I was going to be bashing my fingers and arms off..
    Then its airbox off time, first the top half....making sure you unplug everything from the ignition module (I think) and the MAF....
    The the bottom half of the airbox has to come out....2 x nuts to undo...one at the front and one at the back, then lift the airbox out and put it somewhere safe (Make sure you put all the bolts, screws and plug clips somewhere safe as well)
    Now you'll have something like this...
    I decided to take remove everything from this end of the TIP at this point, DV etc etc. Its just a case of un-doing everything and giving them a pull out...
    So thats the top half sorted out...
    Now its time to get the car jacked up (axle stands please people...dont like hearing about people being squashed by cars falling of jacks!!).
    In this pic you can see the bottom cast section of the TIP. There's small 5mm allen bolt that is holding it onto the turbo. Mine was easy enough to get un-done but thigs are a bit tight down there...
    This little bolt is the only way the TIP is held on at the bottom end. Once it was undone I used a small pry bar to careully split the TIP from the turbo....
    Once this was clear from the turbo I removed the small pipe that goes onto the TIP at the bottom...some pliers, a deep breath and a "F*CK OFF" finally got it shifted.
    It wasnt tight, just really hard to get at with pliers....I shouldnt have lent my mate my long reach needle nose's...oh well.
    Right, now you can pull the TIP out of the engine bay from above, carefull as you do it as mine managed to catch on pretty much everything on the way up.
    Here she is....off at last...
    Time for a pint of ice cold ribena at this point and 5 minutes sitting in the sun....
    Back to work...
    You can see here how the Forge TIP varies over standard...
    Standard item looks quite restricted....bit of a bottle neck there I'd say...
    Forge item, a nice proper bend with an even radius....looking good, hopefully should make it a bit easier for the air getting in.....
    So this is where you have to thread the TIP onto....aw...bless....look how small it is...
    Anway, clear any crap/gunk off the turbo prior to fitting the new TIP.
    This is where the fun started. You have to thread the TIP down through the engine bay and get it down towards the turbo. This was VERY TIGHT, in fact so tight, I had to cut a small amount off the turbo end of the TIP (about 8mm) otherwise there was no way it was going on. Make sure you put the jubilee clip on BEFORE YOU THREAD THE PIPE, YOU'LL NEVER GET IT ON WHEN ITS IN THERE!! (you have been warned).
    So anyway, after a bit of jiggery pokery the pipes sitting roughly where I need it so its under the car again..
    After a lot of pulling and poking and swearing I finally got the TIP onto the turbo. I had to use a pry bar to move the TIP around into place as I couldnt get my hand in there...
    Now its a case of pushing the jubilee clip up as close to the turbo as you can and doing it up....
    Re-attacht the other little hose at the bottom onto the little alloy pipe and thats the bottom half done.
    Back up top you'll now be left with something like this...
    Now its just a case of refitting everything back into the TIP, nice and easy...
    Refit the airbox....bottom in first...
    Now at this point I tried to refit the top half of the airbox and MAF etc but the new TIP was too long to get it all to sit right. So...out comes a very sharp stanley knife blade and I trim a bit of excess off. I attached a jubilee clip that I could use as a straight edge to ensure a nice smooth cut.
    It only needed a bit taking off...
    So now I can refit the top of the airbox and MAF and plug everything back in, engine cover back on etc.
    Now we're there....fitted.....phew!...
    So thats it....done. Took about an hour and a bit to do. its tricky and bloody tight on mine, mines a 1.8T AGU running a KO3 turbo just for reference.
    So now its a case of starting it up and making sure its OK, which it was. Tools away and back into the house for a well deserved cup of tea and a few slices of fruit cake to celebrate my victory...
    Job done, nyom nyom nyom
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Jun 2009
    1,064
    nice right up!.. looks pretty simple actually, sounds fiddally though, be bit gutted if ya messed up them cuts though!. hope the underneath of my cars alright being quattro dont know if its tighter down there. how does it make your car feel though, better?
    Its gone replaced with a mk2 golf gti 16v :D
    Dennis Moeller's Avatar
    Jan 2007
    NorWay
    442
    Excellent write up with good pic's and a humorous twist...Well Done Mate.
    My old car.. Still miss the lil rocket :-)
    Remapped Stage II - Forge FMIC - Dahlb�ck Intake - K&N - DieselGeek ShortShift - Phenolic - Powerflex Dogbone - Rial Daytona Race 8.5x18" ET30 - Forge Tiebars - Bilstein B8 - H&R 25mm - R32 rear ARB - H&R 20mm Spacers - EBC Discs - Red Stuff pads
    ______________________________________________
    NO ONE EVER REALLY DIED
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Yeah its easy enough to do...... its just REALLY tight down there, if I had access to a proper 4 poster ramp it would have been a lot easier. It was all done with me on my back under the car trying to squeeze my arms round driveshafts and antiroll bars. Its just fiddly, small hands and weather thats not 30 degrees would have been a great help
    I've not driven the car yet, I'm off out for dinner in a bit which will involve a drive down some nice twisty country roads so I'll have a play and see whats what.
    Tom
    T
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    I should also add at this point....big props DPM Performance.
    I ordered this the day before yesterday during the evening. It turned up at lunch time today. Very speedy service and a great price
    T
    jesters3's Avatar
    The Shire's
    1,516
    Nice write up, well done for taking the time and photos!
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by jesters3 View Post
    no worries.
    I couldnt find a decent guide online so thought I'd do one myself to save anyone else the head scratching
    ROLTYA3TURBO's Avatar
    essex boy :)
    May 2009
    essex, uk
    247
    great write up tom!much appreciated for taking the time out to document your work gives us all some tips to!nice 1
    '98 azure blue a3 1.8t, forge 007p,KW 40mm springs/shocks,18" polished rs4's,s-style chrome mirros,black diamond front 20 groove discs,ebc greenstuff pads,painted and decal'd calipers,colour-coded engine cover,aero wipers,chrome indicator bulbs,l.e.d xenon sidelight bulbs,h.i.d xenon headlight bulb kit,let the work begin!
    Latest addition - s style chrome mirrors
    Next up - remap,exhaust
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Well its not fallen off yet so thats a good thing.
    I doubt it gives any extra ponies but the car does seem to pick up better, mainly at higher revs rahter than low down, could be due to the new TIP not having that massive restriction on it perhaps?, anyway...all good.
    The DV also sounds different now, more of a 'psshhhhht' than what it was before.
    Tom
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Nice one Tom, excellent write up and pics and job well done.
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    Fantastic Tom - I love fruit cake!!!
    Great write-up, glad you're pleased with the result
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
    jesters3's Avatar
    The Shire's
    1,516
    So you going to do the other boost hoses as well?
    Jester
    Feb 2008
    2,810
    thqanks for that tom mate. good work there. hows the car feeling now then
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    S3 HODGE's Avatar
    Brown passenger seat.
    Apr 2009
    Dorset
    1,177
    Nice write up Tom, Notice a louder DV blow off? Looks sweet aswell, I wana a set of blue ones And i will use this quide when fitting mine as im sure its very simular on the BAM engine.
    The One And Only Brown Bora
    Current: 2007 S3, Solar Orange - Revo Stage1 + all the toys
    Sold: 2000 S3, Black
    Sold: 2003 BAM Nogaro Blue S3, Revo Stage2, 19" Rial Daytona's, AP Coilovers
    Sold: 2001 A3 1.8T
    Sold: 2002 A3 1.8T, Custurd Code, BBS CH, AP Coilovers
    Sold: 1999 A3 1.6, Jewish Racing Gold, S4 Wheels
    Xbox live ID: o_HODGE_o
    PS3 live ID: Hodge_09
    Bignick's Avatar
    Jul 2008
    Kent
    165
    Excellent write up, I was planing on buying one of the de restricted hard pipes from Awesome. Do you think this forge item is better? How much did it cost? , and where did you buy it from ? did it come straight from Forge?
    The light that burns twice as bright , burns half as long.
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    564
    Quote Originally Posted by S3 HODGE View Post
    Can't be 100% on this, but i'm sure i managed to swap the TIP out from the top on mine... No need for crawling about underneath
    ...... Waiting Paitently...
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Quote Originally Posted by S4quatt View Post
    Yes defiantely no need to crawl around underneath on the BAM engine as it doesnt have the hard pipe the standard hose goes straight onto the turbo in the same way the forge one does in the write up above. So its actually an easier job on the S3
    NardoNZ likes this.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Beenon for a few days now and its still not fallen off
    Car feels fine, as I said it seems to pick up a bit better.
    I will be changing the rest of the hoses at the end of the month when payday rolls around
    Tom
    Nick090884's Avatar
    Mar 2012
    rochester
    195
    Nice write up dude loving the bit of humour makes easy reading. It's a good guide and the pictures are good too. i think this will make a lot of people happier to try them selfs. Sweet nice one dude. ill be using this guide to work from defo !
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,695
    This is a massive bump but worth it... We be using this soon
    <Jay A3 build thread>
    241bhp K03s - R Tech
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    729
    Thank you so much for this OP. Just fitted mine today and followed your instructions. Snapped two screwdrivers on jubilee clips that I couldn't get a socket on...and bent an Allen key.
    The only thing I need to change is the top host that does in the DV as it's too curled over and stretched as the TIP is much larger/higher up than the OEM one.
    Never buy cheap **** tools.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Nov 2010
    Newmarket, Suffolk
    71
    Quote Originally Posted by S3Steve View Post
    Thanks for this info!! I just ordered a B5 V3 TIP and I didn't think it would be very hard to install so I was going to do it in my driveway. Although, after reading this thread I was going to take it to the shop and put it on the lift, until I saw this info about the S3. So back to the easy driveway install.
    Boost fiend
    Dec 2008
    Swansea
    207
    How close does the water pipe that runs by the tip should it be?
    The pipe runs on the right of the tip, so the tip is between the pipe and turbo if that makes sense?
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    Boost fiend
    Dec 2008
    Swansea
    207
    I know these have to be moved during tip fitting to make space, is it ok for the pipe to be touching the tip?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    Quote Originally Posted by AFDanHef View Post
    You do realise K04 is nothing like K03 like pictured here yea? and there are already fitting guide in my badger5 section on here.... much easier for k04 tip than k03 one...
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Boost fiend
    Dec 2008
    Swansea
    207
    Quote Originally Posted by Nick101 View Post
    anyone know if it's alright for the pipe to touch the tip?
  28. #27
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Pics?
    <tuffty/>
  29. #28
    Boost fiend
    Dec 2008
    Swansea
    207
    I'll try get outside and get a pic, broken my collarbone Sunday, so easier said than done
  30. #29
    Boost fiend
    Dec 2008
    Swansea
    207
    here you go:
    ignore the red bits on the black pipe, its paint scrapings from the rocker cover.
    Does this look ok?
  31. #30
    Nov 2012
    Kent
    451
    Add Tim_Attard on Facebook
    this is how mine is, it was far to big to fit without it touching, it also touches the back of the engine block
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
  32. #31
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Quote Originally Posted by Tim_Attard View Post
    Longevity?
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  33. #32
    Nov 2012
    Kent
    451
    Quote Originally Posted by [Dave B] View Post
    Longevity?
    i hope its alright tbh there was nothing i could do about it unless i got a smaller pipe?
  34. #33
    Boost fiend
    Dec 2008
    Swansea
    207
    Do you mean the size of the tip you fitted is too big, so touching pipe like mine? I have just bought the car and this is how it is fitted, I'm not happy abit the fit tbh as there is slight chafing there, nothing major, but what could be done to pull the pipe away from the tip?
  35. #34
    Nov 2012
    Kent
    451
    yeah i have the oversized tip from sfs so its pushed right up against it kinda squashing it a little
  36. #35
    Boost fiend
    Dec 2008
    Swansea
    207
    I was more concerned about the temperature of the pipe that's touching it, it seems to have held up fine, it's been on the car for a few years and there is only a tiny mark where it's touched.
    What kind of temps can silicone take before melting?
  1. How to fit exhaust tips?
    By klauster in forum RS3 Forum
    Last Post: 10th May 2013, 20:13
  2. K03S Turbo finally fitted and neuspeed tip and wow!
    By Customboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2012, 21:10
  3. Forge DV - Tips On How To Fit One Please
    By Iggu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th July 2009, 21:09
  4. How to fit a siren to my alarm?
    By imported_norad97 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th September 2005, 11:43
  5. Anyone fitted/know how to fit a Boost guage on a diesel?
    By evomaster3000 in forum Diesel forum
    Last Post: 27th January 2005, 18:13
Tags for this Thread
