EM TuningSky Insurance
Results 1 to 9 of 9
    Jun 2009
    7
    Problem, door sensor?
    Hi, Ive got Audi a3 1.8t sport 02 plate.
    Think got problem with door sensor and most of time seems to be the passanger side, when ever I lock car or driving the interior light
    flashs on and off all the time and can hear a clicking noise and if car is locked it will set alarm off. Somtimes open and closing the door fully stops it but takes a while. Nothing shows up on the dash to say its open.
    Anyone help thanks
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,282
    See if slamming the door helps. I had similar issues with interior lights and door sensors. I had the door lock changed which helped but after further investigation it turned out I had a faulty central locking pump.
    You need to get VAGCOM on the car to find out if you have any errors.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jun 2009
    7
    Thanks for helps, yea tryed slamming it still does it lol,
    S3 Paul's Avatar
    Oct 2006
    2,764
    I had this problems.
    The pin switch that controls the light is inside the door lock, If you look into the door catch you can see the pin switch, Push it in and out a few times with a thin screw driver and maybe spray a little wd40 or something like into the catch. If doing this help ... good times , if not maybe the swich is completely dead.
    Noggy Blue 2001 S3
    Jun 2009
    7
    Thanks! it dont do it all the time, will give it a try thanks
    Spec's Avatar
    Currently just a Clio owner :(
    Jul 2008
    Birmingham, In the Yellow Clio
    84
    Can I bump this thread for further help please..?
    I have this problem. Sometimes the alarm goes off after about 40 seconds.
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Had it a few times myself, nothing a good old slam of the door hasn't fixed yet
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,092
    Spec, dont know why your alarm is going off, it should do and wont have anything to do with the door sensor.
    I normally slam the door or just leave it as it is.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    I had this same problem recently, the alarm would somtimes wake me in the night! Making me rush out to my car expecting the worse only to find the display showing the door was open? I had a local specialist replace the lock which has the micro switch in it cost about 50 for the part plus 30-45mins labour, Think these micro switches are not the best, had the boot do the same thing bout a month later but replaced that myself and was only 28 part, the new boot latch was actualy an 8p part but seems to have done the trick!
    cheers Matt
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
