JMB RetrofitsChris Nott
Thread: Pin Layout
    Typhoon's Avatar
    Dec 2008
    South Africa
    16
    Pin Layout
    Hi there
    I have and AGU A3 and my car cant be port tuned from inside the vehicle as there is one pin missing on my OBD plug not there which was added on them from 2000+
    Do anybody maybe have a pin layout of the newer OBD port on the A3 and to where in the engine ECU they go to with what colour wire?
    Would appreciate if any info could be obtained, i have searched the web and no luck.
    A3 8L 1.8T 99
    DP with complete 63mm exhaust
    40mm lowered, 18' RS4 Mattblack
    Forge Splt-R, N75J
    Port Tuned by FRC
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    As you say you cant 'flash' tune an agu ecu, unfortunatly its a case of soldering a new chip directly onto the ecu circuit board. I'm not sure even if you find that extra pin it will enable you to port tune the ecu.
    There are plenty of companies that can still tune your ecu regardless of what mods you have.. have a look at some of the sponsers on here for some more help.
    A1 Competition line 1.6 tdi
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Yeah really dont waste your time...just go get it mapped and be done with it. not worth the hassle.
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    Typhoon's Avatar
    Dec 2008
    South Africa
    16
    I had my car mapped eventually, but with a special cable and i had to remove my wiper covers and plug it in directly on the engine ECU, they explained that there is just one "tuning" pin missing on my OBD port on the inside.
    So if i can fit that pin and trace the wire to the ECU and connect it there it should be able to MAP my car from the inside.. or not?
    If its this easy i will do it, but if it aint, ahh well then i will have to live with it, but il try 1st
    A3 8L 1.8T 99
    Forge Splt-R, N75J
    Port Tuned by FRC
    ...Watching you!
    Earlsfield, London
    5,087
    i think if it was that easy, someone would have done it already. The ECU is different so i suspect it is not that simple.
