Volks AutosChris Nott
Results 1 to 14 of 14
    Russ's Avatar
    Jun 2009
    61
    D2S Bulb in Essex
    My Right side Xenon has blown and it needs a new bulb. Anybody know where I can pick up a 4.3k D2S for a good price in Essex? I hate waiting for things I've ordered online!
    S3 HODGE's Avatar
    Brown passenger seat.
    Apr 2009
    Dorset
    1,177
    Cheak your fuse....The bulbs **shouldnt** go. I have a Phillips bulb still that i bought online and then found out it was a fuse
    What price were you looking to pay?
    The One And Only Brown Bora
    Current: 2007 S3, Solar Orange - Revo Stage1 + all the toys
    Sold: 2000 S3, Black
    Sold: 2003 BAM Nogaro Blue S3, Revo Stage2, 19" Rial Daytona's, AP Coilovers
    Sold: 2001 A3 1.8T
    Sold: 2002 A3 1.8T, Custurd Code, BBS CH, AP Coilovers
    Sold: 1999 A3 1.6, Jewish Racing Gold, S4 Wheels
    Xbox live ID: o_HODGE_o
    PS3 live ID: Hodge_09
    Russ's Avatar
    Jun 2009
    61
    Ah ok, will swap the bulbs over and check it out.
    From what I've seen the Philips bulbs are around 50 each. Cheapest I've seen was 30 for a pair of unspecified brand
    S3 HODGE's Avatar
    Apr 2009
    Dorset
    1,177
    Ahh right...Are you talking about the gas bulbs? The cheapest i found my Phillips one for was just over 100.
    Sold: 2001 A3 1.8T
    Russ's Avatar
    Jun 2009
    61
    I assume they're gas bulbs, don't really know to be honest. 100 a bulb is just mad!
    Aug 2004
    526
    could be the ballast also - if you leave the switch on for 15-20 secs and then turn on and off does it fire up?
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    The cheapest place is online, if you need a D2S bulb straight away the only place you can really get them from is dealerships, and it can be anything between 80 to upwards of 100 for a bulb. I had a set of unbranded ones in my R32, both S3's and A4 and they didn't give me any problems at all. Got them for 30 so the difference in price was well worth the extra day or two I had to wait until it arrived.
    Try aceparts.com or have a look at these bad boys on their eBay shop. They are 5000k colour temp and if you buy now you might be able to get them tomorrow morning.
    Aug 2004
    526
    Quote Originally Posted by golf View Post
    Try aceparts.com.
    second that - i have 30 e-bay jobbies which are fine.
    Russ's Avatar
    Jun 2009
    61
    Bloody hope it's not the ballast although based on the threads on here it's quite common. Will check it all out tonight methinks. Here's hoping it's just a fuse!
    Russ's Avatar
    Jun 2009
    61
    Well though I'd swap the bulbs but after taking off the back cover for the headlight the cable for the Xenon came straight off the bulb as well. Unfortunately it also doesn't lock back on and the entire inside of the light moves back and forth. The bulb works though
    Either the inside fitting has somehow slipped off of the adjuster or it's broken. Means that the wheels and bumper have to come of this weekend so that I can take out the light and take a better look at the headlight. Ingenious design there...
    Joys of owning a car hey?
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    The headlights aren't very robust, and my drivers side headlight casing is also loose which can affect beam pattern. I'd be interested to see whether you manage to sort out the loose headlight fitting, because it's a pain in the arse to fix.
    Russ's Avatar
    Jun 2009
    61
    Had a look today and found the problem
    see where the central unit has come off of the adjustment runners. Took off the motor unit (I think) and pulled it on with some needlenose pliers, not sure how long it's going to hold on for.
    Looks like someone has had it apart before, hopefully avoided getting a new headlight for a while though
    Having a signature for the sake of it...
    Feb 2008
    2,817
    whats the difference between the bulb and the ballast guys? what are the original bulbs K temp wise?
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Quote Originally Posted by S3 Rav View Post
    I don't know why you've posted this in this thread rather than in the new one you created?
    The ballast is the igniter which enables the HID's to power up, and is tucked away underneath the headlight behind the front bumper. I'm sure you know what a bulb is! The original bulbs are Philips 4300k's, but they tend to colourshift to a slightly higher temp after a few years.
