Volks AutosSky Insurance
Results 1 to 18 of 18
    S3 Paul's Avatar
    Oct 2006
    2,764
    Removing the drivers side air vent...
    Ive Bought a air vent gauge pod for my AFR guage...
    I bought the full vent kit from awesome GTI but my problem now is how the vent comes out. The new one shows no bolts or clips... all i can see are 4 things that look like they may hold the pipework to the vent... I realy need to know how to get the bloodything out !
    Anybody else taken it out for any reason i would be greatfull if you could tell me how.
    Noggy Blue 2001 S3
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    IIRC you may need to remove the fuse box to get to the back of the vent.
    S3 Paul's Avatar
    Oct 2006
    2,764
    I have removed the lower dash trim and fuse box. Still can not work out how it is removed. I realy dont want to start breaking anything or marking trim that is seen.
    Noggy Blue 2001 S3
    Jun 2009
    North Cornwall
    171
    Never knew those existed!
    Did you buy the whole pod or just the insert?
    S3 Paul's Avatar
    Oct 2006
    2,764
    Full vent replacement. its from awesome gti.
    Looks factory to be honest. but god knows how the standard one comes out !
    Noggy Blue 2001 S3
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    If its anthing like An A4, its pushed in. Can you not tell how its fitted from the vent you have?
    S3 Paul's Avatar
    Oct 2006
    2,764
    From the new vent it does look like it pushes in then the clips on it will hold it in but... im unsure if it clips to the ducting or the dash, I darent just pull and pull till something gives.
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    If you have a face lift, you need to disconnect the wires to the illuminated vent dial, then it should (with gentle assistance) prise out from the front... it is very tight so use a large flat screwdriver with someting wrapped around the end so as not to mark any thing.
    I had this fun and games when I did my boost gauge however I stealthed mine behind the grille
    <tuffty/>
    S£'s Avatar
    Mar 2008
    Suffolk
    669
    I done mine by removing the slats and getting my hand in there to pull it, but as tuffty said be careful with the wires to the illuminated vent dial.
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    They look brilliant. I quite fancy the Liquid though as it does alot of what the vagcom does (obviously not quite as detailed!) and fits nicely in place. Very tempted
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Whats this illuminated vent dial you lot are on about?
    S3 Paul's Avatar
    Oct 2006
    2,764
    The wheel that controls how open or closed the vent is... the white marks light up red like the dash clocks and switchs
    Noggy Blue 2001 S3
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    The factory tool for removing the vents is just a hook. It can be fashioned easily and make the task a breeze.
    Homemade tool
    To use, insert through the vent and hook it at the rear near the top, bottom or sides and pull. You can make a pair of hooks to make things easier if required.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    I've got a load of old bike wheel spokes if anyone wants any!.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Im no sure if mine actualy lights up!
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Pre facelift don't light up do they?
    Also check your dash dimmer isn't too low!
    AUTOMAP
    www.eliteremaps.com
    S3 Paul's Avatar
    Oct 2006
    2,764
    HTC... your a star.
    I will be trying this in the morning.
    Noggy Blue 2001 S3
    audia38l1's Avatar
    Jun 2012
    24
    Thanks for this posting. I am going to do the same to remove the vent as there are so many sponge debris blowing off from inside the vent and making the interior really dirty. I am not sure if this scenario happens to you all and if so, how do you guys deal with that?
