Chris NottAH Fabrications
Results 1 to 9 of 9
    Feb 2009
    31
    6 inch components in front doors
    Was wondering whether anyone has done builds to house 6 inch components in their front doors?
    If so could you post some photos please.
    kaizokuninja's Avatar
    Mar 2009
    Norwich
    144
    There are components in the front door anyway? Why not just replace them with some high quality ones?
    Audi A3 1.8T | Ming Blue | Tan Leather | Aero Wipers | Neeeeed $$$$$$$
    Feb 2009
    31
    Quote Originally Posted by kaizokuninja View Post
    I have already replaced the standard speakers with focal 5 inch components but they just don't compete with 6 inch speakers which give you so much more depth to the front stage due to the range they can handle. I had a golf before with 6 inch focal components in the front and I really miss the sound that I had, plus the speakers are just sat on my garage floor nowthey need to be fitted!
    Keeno's Avatar
    Spooly Spooly Boosty Boosty!
    Apr 2009
    West Sussex
    695
    If you find the best part of 300 down the back of the sofa you could give audioscape a go. Not sure if they do Audi fitment pods, but I looked into some for my old mk3 polo GT. 270 the pair...
    http://audioscape.co.uk
    Cheap and Reliable is not Fast. Cheap and Fast is not Reliable. Fast and Reliable is not Cheap!
    Dansmith's Avatar
    Apr 2009
    Bournemouth, United Kingdom
    459
    I Don't understand what difference a larger speaker in the front would make, better quality magnet sure will make a huge difference!
    Bigger speaker cone means more bass? BUT the larger the speaker cone the looser the mid's and top's become........ making the sound actually become more sloppy......(If this is wrong in car audio please correct me but this is how it works in studios, and guitar amps)
    Would you not be better sending more power to the rear of the car (maybe 65% fade) and then the amp will send more of the bass to the back, this would give you punchy bass in the back but nice crispy mid's and tops in the front.
    Maybe if your amp isn't doing this naturally get a decent external equalizer or put filters on the front speakers (i'm pretty sure both are on the market)
    (please don't judge me I'm not one to upgrade my car stereo's just part of my degree was sound engineering)
    Feb 2009
    31
    Thanks for the replies people.
    Just thought there may be some audio enthusiasts out there that had already done builds in their cars.
    Even with the uprated speakers in the original mounts, as the standard grills were not designed for this size speaker they cut across the face of the speaker and block the sound. Plus they are facing at each other, not to a centralised point at the roof, which is what you should aim for in order to acheive a good sound stage from the front speakers.
    To get the best sound in a car, IMO, you want to be getting most of the sound from the front speakers and merely 'fill' the sound with the rears. So this is why I am trying to put 6 inch in the front as the vocals are so much richer and warmer.
    I might be being slightly perverse about this but I spend a fair bit of time in my car and have got used to quality sound in my previous cars
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    MArty..your best off mailing andymac....he's normally on the audio section of the forum and does some MDF adaptors that will allow you to fit these without the crappy original mounts (as i seem to rem there being clearance issues)
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Jun 2003
    World of my own
    9,813
    The main problem with the fronts on the 8L is that they're mounted to the flimsy door card which is loosely clipped to a metal door, the door has no inner skin so mounting to something solid is impossible. The second problem is space. If you still want the windows to work then you only have 50-54mm depth to play with. Custom door builds would require bringing the speaker part of the door panel out from the current position to give you the required depth. You'd then need to build a robust baffle for the speaker to mount to, and there's little to attach this to apart from the corner edge of the door skin. Not at all impossible but a lot of work. Jehnert are the best IIRC, but you're looking at 400+ just for the door board:
    http://www.jehnert.de/typo3/index.ph...8b776d53457e73
    Easier to go the stealth sub route and stick with 5.25" replacement components in the front. Yes it's a compromise but a bloody good one and unlike typical 10-12" subs the 6.5" JL unit does provide a surprising amount of mid bass to make up for the deficiencies from the cabin setup.
    http://www.dizzythedog.com/index.php...tealth_sub&a=0
    Alex Turner
    Feb 2008
    2,810
    i've got a pair of focal utopias 5.25 to go in the fronts. got to check the depths though. linked up to my rockford HU should sound good good.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
