AH FabricationsSky Insurance
Results 1 to 13 of 13
    smo
    TDi Power
    Dec 2006
    Devon
    53
    Poor Economy - please help
    I have a 2003 TDi PD 130 which until fairly recently was returning a decent economy of approx 45-50mpg depending on use (when i got it 2 yrs ago it did nearly 60mpg!)
    However, its not returning 35mpg if i'm lucky - can anyone give me suggestions as to why this might be and what i should be checking to find out whats going wrong?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Could be your maf meter, give it a clean and see how you get on.
    S3 Dave's Avatar
    Now running on Heavy Oil
    Jul 2007
    Middle England
    432
    MAF MAF MAF MAF MMMAAAFFF
    Time for a vag-com check but it was a more common problem on the trusty Pd's than the petrol!
    "Never in the field of human conflict was so much owed by so many to so few"
    Churchill August 20th 1940
    smo
    TDi Power
    Dec 2006
    Devon
    53
    Tried to check the MAF but cannot physically remove it due to being fitted with security bolts
    I dont have VAG-COM and it doesnt appear there is anyone round here that does
    Dansmith's Avatar
    Apr 2009
    Bournemouth, United Kingdom
    460
    I think your rubbing in 35 mpg! im lucky to get 25! lol
    smo
    TDi Power
    Dec 2006
    Devon
    53
    Quote Originally Posted by Dansmith View Post
    Yes but you dont drive an economical diesel that should be returning 50+mpg!
    Dansmith's Avatar
    Apr 2009
    460
    ok ok I will be a little more serious, when was the last time you had a general service? oil change etc, sounds stupid but it really makes a difference, in my old 1.8t I used to go from 40 mpg to 28 if it was needing a service!
    smo
    TDi Power
    Dec 2006
    Devon
    53
    About 3-4K ago including oil, air filters etc..so fairly recently as i tend to clock up miles (although less so since xmas)....just about to hit 190,000 on the clock!
    Feb 2008
    14
    Is your thermostat showing 90 all the time? If not, that means it needs replacing and a side effect of this is that the car runs a bit rich, lowering your MPG as I found out myself. However I do have a 1.8T so it may be slightly different.
    smo
    TDi Power
    Dec 2006
    Devon
    53
    Quote Originally Posted by Turbo Lag View Post
    Strangely enough it varies from journey to journey however it rarely reads 90 like it should so....
    Jun 2009
    North Cornwall
    171
    Where abouts are you in Devon? Were in Cornwall and have vagcom, although ive just started using it so im still figuring it all out but happy to meet up sometime if you want to give it a try.
    Were off to Plymouth on the 20th of this month to AP Motors if you can wait until then?
    smo
    TDi Power
    Dec 2006
    Devon
    53
    I'm near Torquay, its a very kind offer that i might well take you up on. Going to change the thermostat first and see how it goes...
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    I'd check car with VAG-COM before replacing anything. It will be time well spent.
    Does it feel like it is performing the same or has the 'go' gone with the economy.
    There was a VW specialist in Torquay/Paignton when I was last there in 97 Can't remember the name though.
    A mate of mine had a Passat PD and he had poor fuel consumption, I told him to go to VW cos they were doing warranty jobs on MAFs at the time. He nearly killed himself leaving the dealers, when he planted it and it shot off up the road.
    My money would be on the MAF but VAG-COM would prove it first.
    Gavin
