Volks AutosAH Fabrications
Results 1 to 37 of 37
    Leon's Avatar
    Jul 2003
    Manchester
    147
    Creaking Suspension
    Hi All.
    Looking for some advice with an odd problem I'm having with my car, 2000 S3 with 44K on the clock. Whenever I start off in the morning, or home from work the I don't hear any noises with the suspension at all, even if I'm going over speed bumps. At some point into the journey though a loud creaking noise appears from underneath the car (trust me I'm not really heavy and it isn't the seat!) which is induced by any body movement. In particular, when the front wheels go over a speed bump (on either wheel, makes no difference) it is very noticable. I don't however hear any noise when the rear wheels go over the hump?
    I am hoping it is something like the shocks which may have gone, unusual for the mileage but possible. Has anyone had similar issues or have any thoughts?
    Feb 2004
    Reading, Berkshire
    146
    Re: Creaking Suspension
    This is going to be the bushes. There have been a couple of posts about this recently - one even had the same title. Try using the search [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Mar 2003
    The Netherlands
    42
    Indeed, I seem to have the same problem. Diagnosis => bushes. Will have them changed after holliday and see if this is the problem.
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    May 2004
    Stockholm, Sweden
    32
    Same prob here, was the bushes expensive?
    chimmo's Avatar
    Nov 2003
    Cambridgeshire
    59
    [ QUOTE ]
    Leon said:
    Hi All.
    [/ QUOTE ]
    I have an identical creak to that Leon.
    Was identified by Audi as anti roll bar bushes. Seeing as the car is still under warranty they will be replacing both front ant roll bar and bushes. Am booked in next Friday 30th to have both replaced.
    The downside is I've had to wait 7 weeks [img]/ubbthreads/images/graemlins/crazy.gif[/img] for the anti roll bar to be delivered as there weren't any standard available in the country.
    Will report back once it's done [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Nov 2003
    Milton Keynes
    54
    Same here!
    Waited 7 weeks for Anti Roll Bar too!
    chimmo's Avatar
    Nov 2003
    Cambridgeshire
    59
    So you had the same problem with the creaking too then gilbo? If so, did the replacement sort it out?
    Leon's Avatar
    Jul 2003
    Manchester
    147
    Chimmo - looks like I'll have to book mine in as well, reassuring to know what the problem is. I'm assuming Audi told you it was safe to drive the car while you waited for the parts to arrive?
    Leon
    chimmo's Avatar
    Nov 2003
    Cambridgeshire
    59
    They never mentioned anything about it being dangerous. They said the creak is to do with the bushes 'wearing', therefore the anti roll bar effectively rubbing (under pressure ie speed humps etc) against them. I think this is the reason they have decided to replace the anti roll itself aswell as the bushes.
    Ben
    Nov 2003
    Milton Keynes
    54
    Sorry Chimmo, my last msg wasn't clear. My car is booked in on Weds 28th for the work.
    Bedford Audi gave me exactly the same explanation that you got.
    I had this problem around 6 months ago too, which was cured under warrenty. Was told it was bushes then too. Not sure how many bushes there are (front/rear?)
    I'll let you know how I get on
    adamgroves's Avatar
    Jun 2004
    North Yorks - Northallerton
    59
    i've fixed my supposed suspension creak. It turned out that it was nothing to do with the suspension. The centre exhaust pipe is held up by a bracket that the pipe is welded too. The weld had broken so when ever i went over a bump the exhaust pipe rattled against the bar under the car. All i did was used a jubilee clip to secure it
    chimmo's Avatar
    Nov 2003
    Cambridgeshire
    59
    [ QUOTE ]
    [/ QUOTE ]
    Gilbo, that's a coincidence as it was Bedford Audi who told me that too!!! [img]/ubbthreads/images/graemlins/grin.gif[/img] It must be their standard response for creaky suspension [img]/ubbthreads/images/graemlins/crazy.gif[/img] [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    Is it Bedford where you're having the work done? Have you had any work done there before? If so, what is your impression the 'team'?
    Feb 2004
    Reading, Berkshire
    146
    @Leon, I spoke to AmD about getting the poly bushes fitted - they quoted me about 250. Will probably get it done at my next service.
    Nov 2003
    Milton Keynes
    54
    Got the car into Bedford Audi today.
    replaced bushes and anti-roll bar - all good now!
    Still got to sort erratic idle as they couldn't find a problem though.....
    May 2004
    Surrey
    310
    dont mean to be rude lads but i think mine needs this. how much did it cost you?
    thanks
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Might just be the recall for the rear seat belts and brake servo pipe.
    Not heard about a recall for the arb bushes.
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Hmm might have to take mine in for them to have a look then if it's being done as a recall [img]/ubbthreads/images/graemlins/wink.gif[/img]
    pwnorman's Avatar
    May 2003
    north yorkshire
    402
    Mines just started making that creaking noise going over speed bumps to, it doesnt do it over other bumps though and stranglely not over the one where i work.I'll be getting it booked in on monday as warranty runs out soon, bloody thing.
    Jan 2004
    24
    Hi there!
    How strange is that? I am taking my car to Bedford Audi on Wednesday for the ssme problem, they have replaced the ARBS once already but this didn't rectify the noise, maybe bushes next. Just had the APR 6 Hour trial from the TT shop round the corner and am nothing short of impressed!
    Ant
    jesters3's Avatar
    The Shire's
    1,516
    Morning,
    Just got mine back from the garage, they had to replace the haldex/diff on the S3, 3000.00 was the bill. Thank god I had the extended warranty, best 400.00 I ever spent!!!
    All the creaks, groans and clunks have gone which is nice and the car is running well, it certainly came into it's own after last nights torrential downpour.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,427
    [ QUOTE ]
    jesterS3 said:
    Morning,
    [/ QUOTE ]
    [img]/ubbthreads/images/graemlins/shocked2.gif[/img] Better start to drive slower then.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    jesterS3 said:
    Morning,
    [/ QUOTE ]
    Anything to do with your recent accident?
    Rich
    pwnorman's Avatar
    May 2003
    north yorkshire
    402
    Got mine booked in for roll bar and bushes, very strnge thing is that theyve got them in stock just have to wait till a week on wednesday to get a courtesy car.i asked how much it would be if it wasnt coverd by warrenty answer was just over 500 the ar*e nearly fell out of my pants again seeing it just had 1300 on replaicing cam timing chain and tensioner.
    jesters3's Avatar
    The Shire's
    1,516
    [ QUOTE ]
    RichA3Turbo said:
    [ QUOTE ]
    jesterS3 said:
    Morning,
    [/ QUOTE ]
    Rich
    [/ QUOTE ]
    Fortunatley not, the accident was just cosmetic damage. The crash bar and subframe are all intact and lovely. They couldn't explain why or how it may have happened. Unfortunaltey I will be none the wiser as the part has been shipped off to Audi to be checked.
    jesters3's Avatar
    The Shire's
    1,516
    [ QUOTE ]
    jojo said:
    [ QUOTE ]
    jesterS3 said:
    Morning,
    [/ QUOTE ]
    [/ QUOTE ]
    Nah, keep on going [img]/ubbthreads/images/graemlins/groovy.gif[/img] The haldex has been pre tested and run so just jump in and crack on was the comment on how to drive it
    imported_Skywalker
    [ QUOTE ]
    [/ QUOTE ]
    That's weird. My dealer (Northampton Audi) said 200. No wonder we call them stealers!!
  28. #27
    pwnorman's Avatar
    May 2003
    north yorkshire
    402
    Its a good job i aint paying for it of course you get the usal rubish of they have todo the wheel alinement because they take the front end of and all that and labour is 75 an hour (its a bargin).Think i'm going to set up tobe a grease monkey me self and charge 70 an hour get parts off e-bay i'll be laughing all the way to the bank. [img]/ubbthreads/images/graemlins/grin.gif[/img]
  29. #28
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    they dont pay us that though 70 an hour would be lovely, unfortunately 10 n hour is about the best we get, to the top of my knowledge we charge 3hrs labour and parts on top, labour rate of 87 per hour, it takes the best part of 2 hours to do quicker when you have done a few!! really you should have to do the 4 wheel alignment but if you pt the frame back in the same place then it is normally ok,and as for dealers saying that you should have to do a 4 wheel alignmen they are correct, the machine cannot be cheated any more by skipping the unneeded measurements, you have to follow the full programme! therefore is why we charge 2 hrs to do this job. but if you dont want it done then just say!!but dont blame me when your tyres start wearing irregularly!
  30. #29
    imported_roydonaldson
    Well, my nice silver S3 has started creaking from the underneath when I go over the brick
    speed bumps in the business park I work in. So, it's booked to go into Lomond Audi in Glasgow
    to be looked over on Thursday.
    Let's see what they say about it ?
    Anyone had their cars in for the suspension at Lomond before ?
    Roy.
  31. #30
    pwnorman's Avatar
    May 2003
    north yorkshire
    402
    [ QUOTE ]
    [/ QUOTE ]I'm glad to here that they cant cheat the machine and i'd prefer to pay the technitions or whatever there called nowa days rather than stealers gettin such a large share as long as job gets done right.
  32. #31
    56
    After reading these posts i am peed off!
    I have exactly the same knocking noise on me 2000 S3, it was viewed under warranty donkeys ok but they couldn't find a problem. Yes I should have caused some stink then! And I have been living with the noise ever since.
    Now the car is almost four years old and out of warrenty. This noise has been with me a heck of a long time and I feel a little cheated by the people who should have known more than me. Can i go back to Audi and demand they replace the rear bushes?
    I wont be very happy with a 200 quid bill for something that should have been sorted in warranty
    [img]/ubbthreads/images/graemlins/burningmad.gif[/img]
  33. #32
    foolish3uk's Avatar
    Aug 2004
    458
    you can try as it was reported whilst in warranty but dont hold your breath, you must understand that just because it happens on you it might not happen when the tech looks at the vehicle!!! trust me ive been there!!
  34. #33
    imported_hornet_basher
    Doh!!
    Had my S3 a few weeks and the front left side has started to creak and seams to be slowly getting worse, and its 2k out of cover.
    Has anyone done the bushes/link rods themselves ? that can write a quick how to, with the parts , part no's and the costs?
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Hi Guys,
    I posted one of the other threads about this problem, I've had a right giggle with the dealers over the last month, and it's not finished yet!!!
    Had the service done at aston green audi in slough, guy came with me on test drive to hear / feel the faults. He agreed with my conclusion that is is probably the ARB and bushes, but would get someone to check and quote. also I had a loose / knocking feeling from the steering (see later). they couldn't fix the problem that day and couldn't offer to fix it until the following week when I was down in plymouth so no help there...
    Went into plymouth Audi (as the phones are useless, same with slough) and explained I had a quote from slough and just needed the work done, so they said they would contact slough and find out which parts were needed... week and a half later after a number of calls and visits, I told them to give up with aston green in slough and re diagnose the problems...
    For anyone that's still reading... especially those about to spend money on the ARB issue... don't!!! I said I wanted to have a look under the car with the technicians, it was at this point I realised the people down here in plymouth actually do have brains! They were great... we (me and most of the mechanics) we're looking at the different faults, the track rod ball joint on the drivers side was very dangerous the worst one they had ever seen, let aston green let me drive the car away...
    And as for the creaking sound (mine was always from the back of the car) it is clearly coming from the bushes on the lower suspension arms, not the ARB!!! which might explain why you guys have had no luck with changing those! the garage didn't even want to replace them straight away they want to try cleaning them first, and see if that helps, will let you all know on thursday!
    Other than that the plymouth guys are great and made my car safe to drive before the end of the day, even though I'd only got there at 12pm...
    sorry this goes on for a while, just wanted to share my experiences, especially as there are lots of people that could be spending lots of money on the wrong parts!
    cheers, this forum is fantastic!
  36. #35
    56
    Thanks for the update my S3 is going into Glos AUDI on Friday. So will update you all on what they do or do not see. I did also take this up with AUDI HQ in milton Keynes, they will look into payments if any faults are found.
    I also called Forge about this, they are not aware of this problem with the A3/S3 range however they did suggest that a soapy solution on the busshes is a good way to see if its the bushes. If the creaking noise goes the bushes are at fault.
    later
  37. #36
    Well, that's my S3 just been brought back to me from the dealers.
    They are ordering a new Anti-roll bar and bushes for the front suspension and hopefully I should have them on the car in the next couple of weeks.
  38. #37
    Just had the anti-roll bar and bushes replaced on my S3 today. Its like a new car again. I had it done at Swindon Audi who were excellent in every way. Total cost was 189.15 (61.98 for bar and bushes, 99 labour and then the dreaded VAT.) This included pick/drop off from my workplace and a good clean in and out.
    They only charged me for an hour and a bits labour, and asking around most places would of charged anything upto 3 or 4 hours so I hope I got a bargain.
    Well happy.
